Imac G5 20'' Recap... Shades Of Blue
  • cheebster
    • May 2008
    • 374
    Hi. First of all, thanks for this great forum to all the contributors.
    I just recapped a imac G5 20''. The caps all looked good, all Rubycon MCZ. I think i did it all (24 6.3V 1800uf, 5 16V 1000uf) for nothing, the issue i had is still there.
    After digging a bit more here, i found out the issue was located in the psu instead (Ltec caps...). After opening up the psu, they all LOOK fine. Are they fine, don't know.
    Should i buy another recap kit to do this part as well ? All the imac does is booting to a blue screen where it shifts from diff. shades of blue, which seems to be rather common with these units.
    Thanks for any input..
  • cheebster
    • May 2008
    • 374
    Re: Imac G5 20'' Recap... Shades Of Blue
    Bump !
      • 31246
      looks can be deceiving.
      • cheebster
        • May 2008
        • 374
        Yeah. But this time, i lost my time i think. Is the psu the source of my issue, anyone thinks ? (the ltecs..)
        • godonr
          • May 2009
          • 111
          Do a search here for "Imac G5" and you'll find a wealth of info. As far as the p/s, you need to verify the voltages. Unplug from m/b and jumper 15+16 to turn p/s on. You should see 24vdc on 22. Not sure where it is but there's a list of the other voltages here also. If you have the Apple Service Diagnostic, you should run it. Also, don't rule out a bad OS load or hard drive as the problem.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            PM this guy.
            https://www.badcaps.net/forum/member.php?u=4727
            He knows at least some of those MAC PSUs inside and out.
            Mann-Made Global Warming.
            - Dr Seuss
            • godonr
              • May 2009
              • 111
              Did you recap because of the blue screen? If so, you should know that with OSX, the blue screen indicates the launchd process is trying to run which includes basic system init tasks and fs consistency checks. This is all software related. Try booting in safe mode (shift key down while starting). If you're UNIX literate, there are ways to move associated startup files but usually it's easiest to reload the OS.
              • Toasty
                • Jul 2007
                • 4171
                The original problem was the video, correct?
                Are the 3 green LEDs on mainboard illuminated?
                Does it chime on startup?
                Video problems can (are known to) be directly related to these units bad PSU's. Which PSU do you have? Manufacturer & Apple p/n please...
                Your PM stated Ltec caps in the PSU. Those are "replace on sight" in my book.
                Toast
                veritas odium parit
                • cheebster
                  • May 2008
                  • 374
                  The original problem was the diff. shades of blue when booting.
                  It does chime on startup !
                  The 3 leds are green, i get the apple logo, then i get the loading thing that turns for a while, then a blue screen shifting from diff. shades. At this point,
                  The psu is a AC-BEL Apple P/N 614-0326 model API4PC46
                  Rev A
                  Thanks !!!
                  • Toasty
                    • Jul 2007
                    • 4171
                    Have you tried doing a "safe boot"?
                    http://support.apple.com/kb/ht1564
                    veritas odium parit
                    • iheartbeets
                      • Jul 2010
                      Identical problem. 20" ALS model. Chime sounds every time. Every 20 or so times, the display actually powers up, shows the logo and circular waiting device, then goes to various shades of blue. Is this the PSU or the MOB? AHHHHHHH!!
                      Thanks,
                      Dustin
                      • badassbarber
                        • Jun 2011
                        i have a imac g5 20 inch als. when i start up the computer, everything starts up fine but the picture is all fuzzy and blury. all three leds on motherboard are solid green and the capacitors all look fine. i have reset the PRAM but no luck....any ideas what it could be?????james
                        • Toasty
                          • Jul 2007
                          • 4171
                          From one of the other threads where a reply was made:
                          Originally posted by godonr
                          If you have AHT (AppleHardwareTest) DVD run it to verify video ram.
                          veritas odium parit
                          • marthyr
                            • Sep 2009
                            I have seen that before on intel based motherboards.
                            Have you ear about gpu reballing?
                            That could be your problem
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              You will see it on everything during the transition time to RoHS BGA.
                              Not even just IT equipment. Those were bad years to buy a fridge or a car.
                              [Or an airplane, or a satellite.]
                              Not to be confused with nVidia's problems.
                              nVidia had that problem and more.
                              - Dr Seuss
                                Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-07-2024, 05:50 AM
                                Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-07-2024, 05:00 AM
                                Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
