Old DELL Power supply H255E-01 - bad IC106 & R148
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    I have one bad power supply for repair old Dell Desktop PC.
    Model of the power supply is H255E-01 for Dell Optiplex 760.
    It looks that controller IC106 is done. I can not read anything on this IC. Is someone who have a schematic for it? Resistor near the IC is bad too. It is R148 - i need to identify it too. Everything else looks OK, mosfets and fuse is OK. I would like to try fix it.
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Old DELL Power supply H255E-01 - bad IC106 & R148
    Show a photo of the power supply board on both sides
    • bajdik
      • Aug 2015
      • 68
      • Czech Republic
      Pictures.
      • lotas
        • Jan 2016
        • 4921
        • Russia
        Ic106 - tny278pn - tny280pn
        • bajdik
          • Aug 2015
          • 68
          • Czech Republic
          Thank you very much. What do you think about the resistor?
          • bajdik
            • Aug 2015
            • 68
            • Czech Republic
            Anyone can help me, please? Maybe, someone can have it in a scrap Thank you.
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              See what this resistor is connected to on the other side of the board
              • Quality
                • Mar 2017
                • Iran
                R148 is 0.5 ohm resistor
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • Info13
                  Dell H235P-00 Power Supply Failure
                  by Info13
                  A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
                  After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
                  ➡️ First test:
                  The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
                  A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
                  I then followed the advice from the forum and replaced...
                  10-22-2025, 01:52 PM
