Re: A question about PWM IC's
I suspect your ic is damaged, The Vin should be higher than 5v, I suspect it should be around 20v at least to provide around 15 volts on the vdd line for startup. The datasheet doesn't show it but there is likely an internal startup circuit that takes the Vin and provides about 15v to the vdd line to charges the startup cap and start the ic, once it starts the vdd voltage is supplied by a feedback winding from the transformer
I would check the mosfet and source resistor, if they are ok I would replace the ic
Start-up current comes from "VIN" (also, line voltage sense). After it has started, house-keeping power for the IC comes from "VDD".
It is a current mode regulator, so it needs the output voltage sense signal at "FB" and the sensed primary current at "SENSE" to regulate. "RI" sets the switch frequency, and "RT" is for over-temperature protection.
The block diagram shows flyback topology, in which the "transformer" is actually a coupled inductor, in which the "primary" functions as the output inductor.Leave a comment:
So let me see if I am understanding this correctly...
Voltage applied between Vin, VDD and Gnd sends the chip 'high' on the output (Trig) which turns on the FET, allowing current to flow, which signals the 'SENSE' pin, causing the chip to go 'low', whilst at the same time, a signal is detected across the output by the 431 which in turn varies the opto-coupler resistance to signal the 'FB' pin, ultimately affecting the 'TRIG' signal frequency.
The chip then goes high again due to the Vin, VDD and Gnd and the process repeats at many KHz
Forgetting any other pin for now, is it essentially something like that?
EDIT
I'm a bit confused...
Looking at the datasheet and the 'Typical Application', the VDD pin connects to an electrolytic, a resistor, a diode, an inductor, and then straight to Gnd.
On the 'Terminal Assignments' however, it has VDD as 'DC Power Supply pin.' I had assumed that had meant 5v or so, but clearly not.
Therefore this chip should need 5v in the Vin, compared to 0v on the Gnd and VDD.
That is what I am measuring anyway.Last edited by Crystaleyes; 04-14-2022, 09:00 AM.Leave a comment:
This something like a micro controller of some type or on some devices you can just not use it or you have either make it high or low depending on the device data sheetLeave a comment:
ThanksLeave a comment:
Lot of power on pins need a PWM signal for it to work correctlyLeave a comment:
I'm learning about SMPS's and am needing a deeper understanding of the control circuitry.
I have a small lighting PSU which has one of these IC's and it has ~5v on the Vin pin yet is not 'chopping'.
Therefore there is nothing happening on the primary or secondary of the transformer, and therefore no feedback signal, nor current flow for the FB and CS pins to detect.
That is why I askedLeave a comment:
On page 3 of your attached pfd files it explains what each pin is used for. Then if you go to page 4 it gives you an internal block diagram of the chip. Inside the block diagram are abbreviations, for each part of the block. On page 5 is the electrical characteristics of the block with the abbreviations and definitions. There is a big "and" gate in the middle which means all signals have to be high in order to get a high out otherwise they are low. The output of the "and" gate goes to the "reset pin" of a flip flop. The other pin of the flip flop is the "set pin" that is connected to the internal oscillator. A flip flop circuit does just that it flips the output Q and Qnot high and low. So, whatever state is high on Q or Qnot it goes low when the reset pin is pulsed. The data sheet has a simple clear to set on these pins which means this is mono state flip flop so the Qnot is high with a high going pulse on set. Then when the reset is triggered most likely a high going pulse then Qnot goes low. Anyway, the data sheet can be broken down for a very good understanding of what the chip is going to need to work.Last edited by keeney123; 04-13-2022, 08:42 PM.Leave a comment:
It usually needs the other signals like CS and feedback, otherwise it will likely shut down.
Why do you ask...Leave a comment:
Hi all.
Do PWM chips usually start triggering with only the +ve and -ve connected or do they need other signals before they start working?
I am particularly asking this for the following chip
https://cdn.badcaps-static.com/pdfs/...2d6a23c015.pdf
Is the VDD needed or should the Vin and Gnd be enough?Attached FilesTags: None
by ductranvinhHi everyone!
The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
Note! This article may or may not be true.
Measurement: (must have boardview of course)
Adjust the impedance scale
12v block
Measure the 12v fuses, see if they burn out.
If the fuse blows, the risk of burning the pcb is...06-29-2022, 05:12 PM -
by sam_sam_samI have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
I tested the battery cells there are installed right now and they are testing good with no issues that I... -
by YellowJacketHi friends,
I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...4 Photos-
by DynaxSCHi Folks
I'm looking for a extreme high current short killer solution for a reasonable cost.
I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
After taking off the socket, the shorts dissappear again.
The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...10-15-2024, 10:13 AM -
Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
The nonvolatile...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:55 AM -
- Loading...
