A question about PWM IC's
  • R_J
    replied
    Re: A question about PWM IC's
    Originally posted by Crystaleyes
    Hi R_J.
    I'm learning about SMPS's and am needing a deeper understanding of the control circuitry.
    I have a small lighting PSU which has one of these IC's and it has ~5v on the Vin pin yet is not 'chopping'.
    Therefore there is nothing happening on the primary or secondary of the transformer, and therefore no feedback signal, nor current flow for the FB and CS pins to detect.
    That is why I asked
    I suspect your ic is damaged, The Vin should be higher than 5v, I suspect it should be around 20v at least to provide around 15 volts on the vdd line for startup. The datasheet doesn't show it but there is likely an internal startup circuit that takes the Vin and provides about 15v to the vdd line to charges the startup cap and start the ic, once it starts the vdd voltage is supplied by a feedback winding from the transformer
    I would check the mosfet and source resistor, if they are ok I would replace the ic
  • PeteS in CA
    replied
    Start-up current comes from "VIN" (also, line voltage sense). After it has started, house-keeping power for the IC comes from "VDD".
    It is a current mode regulator, so it needs the output voltage sense signal at "FB" and the sensed primary current at "SENSE" to regulate. "RI" sets the switch frequency, and "RT" is for over-temperature protection.
    The block diagram shows flyback topology, in which the "transformer" is actually a coupled inductor, in which the "primary" functions as the output inductor.
  • Crystaleyes
    replied
    So let me see if I am understanding this correctly...
    Voltage applied between Vin, VDD and Gnd sends the chip 'high' on the output (Trig) which turns on the FET, allowing current to flow, which signals the 'SENSE' pin, causing the chip to go 'low', whilst at the same time, a signal is detected across the output by the 431 which in turn varies the opto-coupler resistance to signal the 'FB' pin, ultimately affecting the 'TRIG' signal frequency.
    The chip then goes high again due to the Vin, VDD and Gnd and the process repeats at many KHz
    Forgetting any other pin for now, is it essentially something like that?
    EDIT
    I'm a bit confused...
    Looking at the datasheet and the 'Typical Application', the VDD pin connects to an electrolytic, a resistor, a diode, an inductor, and then straight to Gnd.
    On the 'Terminal Assignments' however, it has VDD as 'DC Power Supply pin.' I had assumed that had meant 5v or so, but clearly not.
    Therefore this chip should need 5v in the Vin, compared to 0v on the Gnd and VDD.
    That is what I am measuring anyway.
    replied
    But there must be a 'basic' state in which the PWM chip turns on, no?
    This something like a micro controller of some type or on some devices you can just not use it or you have either make it high or low depending on the device data sheet
  • Crystaleyes
    replied
    Lot of power on pins need a PWM signal for it to work correctly
  • Crystaleyes
    replied
    Originally posted by keeney123
    On page 3 of your attached pfd files it explains what each pin is used for. Then if you go to page 4........
    Obviously I had been looking at all the pages, trying to understand how the chip worked, but reading again, it appears that that the VDD is needed too, so I'll check that out when I get indoors.
    replied
  • Crystaleyes
    replied
    Originally posted by R_J
    It usually needs the other signals like CS and feedback, otherwise it will likely shut down.
    Why do you ask...
    Hi R_J.
    That is why I asked
  • keeney123
    replied
    On page 3 of your attached pfd files it explains what each pin is used for. Then if you go to page 4 it gives you an internal block diagram of the chip. Inside the block diagram are abbreviations, for each part of the block. On page 5 is the electrical characteristics of the block with the abbreviations and definitions. There is a big "and" gate in the middle which means all signals have to be high in order to get a high out otherwise they are low. The output of the "and" gate goes to the "reset pin" of a flip flop. The other pin of the flip flop is the "set pin" that is connected to the internal oscillator. A flip flop circuit does just that it flips the output Q and Qnot high and low. So, whatever state is high on Q or Qnot it goes low when the reset pin is pulsed. The data sheet has a simple clear to set on these pins which means this is mono state flip flop so the Qnot is high with a high going pulse on set. Then when the reset is triggered most likely a high going pulse then Qnot goes low. Anyway, the data sheet can be broken down for a very good understanding of what the chip is going to need to work.
  • R_J
    replied
    Why do you ask...
  • Crystaleyes
    started a topic A question about PWM IC's
    Hi all.
    Do PWM chips usually start triggering with only the +ve and -ve connected or do they need other signals before they start working?
    I am particularly asking this for the following chip
    https://cdn.badcaps-static.com/pdfs/...2d6a23c015.pdf
    Is the VDD needed or should the Vin and Gnd be enough?
  • ductranvinh
    Graphics card repair, Basic Measurements
    by ductranvinh
    Hi everyone!
    The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
    But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
    Note! This article may or may not be true.
    Measurement: (must have boardview of course)
    Adjust the impedance scale
    12v block
    Measure the 12v fuses, see if they burn out.
    If the fuse blows, the risk of burning the pcb is...
    06-29-2022, 05:12 PM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    by sam_sam_sam
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • YellowJacket
    Dell P2416DB - no picture
    by YellowJacket
    Hi friends,
    I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
    01-16-2024, 07:45 AM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
    MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
    Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
    The nonvolatile...
    10-07-2024, 04:55 AM
