A question about PWM IC's
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    #61
    Re: A question about PWM IC's
    Originally posted by R_J
    Just a note on the source resistor, it should be a non-inductive type once you do the final repair. Also without a load on the power supply, the circuit may start but be in burst mode until a load is placed on the secondary. This is a complex, green mode ic, and the circuit operates at high frequency. The whole circuit is fairly simple as the ic does a lot of the work, I suspect and hope the ic should fix the smps.
    Nice one for the heads-up on those points.
    I was unware on 'non-conductive' resistors, so that is for sure good to know.
    There are three different ones here, two are wire-wound, one a fat, green 5W affair and the other looking like a wire-wound carbon.
    The third is a square-edged, white ceramic axial, 2W
    Looking into it, some non-inductive resistors have an extra yellow band, which none of these have. I'll see if I can't get back to the shops today.
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      #62
      Originally posted by keeney123
      As a last thing I can point you to in understanding this circuit and others is this site.
      https://training.ti.com/pulse-width-...pwm-converters
      I find the free ti training course offer a good fundamental understanding.
      Cool.
      Thank you for your patience.
        • Jul 2011
        • 6070
        Thanks for posting this website link for this type of information
        Very informative information
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          I once took an amplifier source from them for free. At the time they actually gave you a test and they graded it. So, your welcome.
          • R_J
            • 9610
            Most non-inductive resistors have a black band as the last band
            In this case I would just use a metal oxide type resistor, like a MOSX2CT52RR12J 0.12Ω/2watt from digikey
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              #66
              The shops were all shut on saturday due to Carnival, but are you saying that this will cause the unit to fail?
              Digikey is a long way from here and the 40 USD postage is too much, so it'll have to be something else, at least for now, until I get back to Europe.
              The new chip is installed, and only the source resistor remains.
              Can the PSU not be switched on for a short period of time, just to verify, or is it absolutely critical to use non-inductive resistors on the source of the switching Mosfets?
              • R_J
                • 9610
                Any resistor should be ok for the source resistor, being such a low value I doubt there would much inductance in even a wire wound resistor. So you should be ok.
                The part number I gave was from digikey KOA Speer electronics, but any supplier should be able to provide a suitable resistor
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  So here is an insight to wire wound resistors.
                  https://eepower.com/resistor-guide/r...und-resistor/#
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    #69
                    A quick update.
                    I replaced the Ic and used a 0.12 ohm ceramic resistor and switched it on.
                    No 24V DC output and no frequency on the gate pin of the IC.
                    Unfortunately I had been using hooks to measure the FET voltages and even though it was switched off, I hadn't waited for the filter caps to discharge before removing them which shorted it out, so until I get a replacement FET there is not a lot else to report.
                    All invaluable lessons, although I am now short of ideas on resolving this.
                    This PSU is not really so important, so I may just take the experience learnt and move on, if a replacement FET does nothing new.
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      #70
                      Thanks.
                      Classic quote from the first page seems to sum up my situation perfectly
                      “The way to succeed is to double your failure rate.”
                      - Thomas J. Watson
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Thanks.
                        - Thomas J. Watson
                        One of my teachers once quoted Thomas Edison on inventing something new. "It's 1% genius and 99% persistence."
                        Edison tried thousands of experiments to come up with the light bulb. He categorized everything he did. One of those things was the foundation for a vacuum tube.
                        My teacher was one of the people who made the first transistor computer that Westinghouse paid $2 million to develop.
                        • ductranvinh
                          Graphics card repair, Basic Measurements
                          by ductranvinh
                          Hi everyone!
                          The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
                          But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
                          Note! This article may or may not be true.
                          Measurement: (must have boardview of course)
                          Adjust the impedance scale
                          12v block
                          Measure the 12v fuses, see if they burn out.
                          If the fuse blows, the risk of burning the pcb is...
                          06-29-2022, 05:12 PM
                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                          by sam_sam_sam
                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                          02-04-2025, 08:08 PM
                        • YellowJacket
                          Dell P2416DB - no picture
                          by YellowJacket
                          Hi friends,
                          I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
                          01-16-2024, 07:45 AM
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                          MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
                          Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
                          The nonvolatile...
                          10-07-2024, 04:55 AM
