Raidmax rx-1000ae PSU weaken - occasional reset
  • Zender
    • Aug 2020
    • 13
    • EU
    Hi, I have my own PSU which have some problems.
    It is about Raidmax rx-1000ae, it run good on idle no problems at all never.
    But is some games it just reset PC without no rule. It can be play for 10 min and reset it can be 30 min or eaven a hour then reset PC..
    To be sure that PSU is problem I put another PSU and testing for days no problem at all.
    So PSU is weaken and in some time when system take more power it obvious put protection and PC restart.
    All voltages are OK, but PG signal is blinking and beeping so I assume that can be problem.
    https://www.youtube.com/watch?v=XNtsfxKpCS4
    Can I do something in this situation does capacitor replacing wil fix the thing ?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: PSU weaken - occasional reset
    Most likely, yes. Raidmax is known to use bad caps.
    If PG is dropping out only with the tester connected, either the main output filters are nearly open, or bad small caps in the control ckts are making the PGO questionable.
    Another suggestion for bad caps is if it's more problematic if it's cooled down after being off a while.
    If/when you recap it, do not omit the small caps.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • Zender
      • Aug 2020
      • 13
      • EU
      Thanks for response.
      I found that I have two big ones that are Teapo 420V and 330uf, and this series of smaller ones which are Teapo 2x 10V 3300uf and 4x 16V 3300uf. There are also smaller ones inside but I can read them well from this point since they are too small.
      For start I'm planing to desolder a big ones 420V and test them with ESR meter to see condition of them.
      As I said PSU works just fine and without any problems at all only is restarting is some certain games, which other PSU that I put into same PC won't do. So there is some kind of problem with it, it is old for about 9 years.
      Specs. i7 2600, rx 580 Sapphire nitro +, 12 GB of ram, 2 x HDD + 1 X SSD, couple of 120mm fans.
      Any sugestion for futher research will be fine.
        • Jul 2011
        • 6023
        Me personally I would think about replacing all of the capacitors on this switching power supply especially the ones sandwiched between the the heat sinks because they are probably cooked to death also being 7 years old and these capacitors are not high quality brand name capacitors to being with
        • Zender
          • Aug 2020
          • 13
          • EU
          Ok, I will desolder all caps and check with ESR meter also do a capacitance measurements with DMM.
          Beside caps do I need to check / replace anything else ?
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Just so you're not chasing a false lead- remember that after desoldering, if those caps are warm when you ESR test them, you can get a false OK reading.
            Let them cool 30 min or so before testing their ESR.
            EOL it...
              • Jul 2011
              • 6023
              Zender
              This is very important to know if you removed them to be tested otherwise your results will not be correct
              But I will add one more thing about this if your results when warm and when cold or room temperature is more than 10% consider them bad compared to a new one
              I repair several devices that had capacitors that had one value when cold ( 50*F ) or room temperature and another value when warm 90*F
              • zunasthegreat
                • Dec 2017
                • 82
                • EU
                Those are Teapo SC, very mediocre caps that really hate heat. 9 years of usage ... these gonna show way bumped capacity (3300uf showing 4000uf) and some might even be in the range of pF. The biggest problem is their 10mm diameter. The 12V ones should be 2200uf 16V 10mmx30mm, the 3.3V/5V ones should be 3300uf 10V and those exist in 10mmX30mm size.
                You live in Slovenia so I guess u can ask user: Behemot for cap replacements.
                • Zender
                  • Aug 2020
                  • 13
                  • EU
                  Guys thanks for response, I don't quit, have big problems how to get into bottom side of the board since this modular PSU are very difficult to work, for days I was thinking how to get to bottom side and finnaly tonight I manage to do it so I can do some work..
                  I desolder a big ones 420V and 330uf, and from what I see they are ok.
                  Capacitance test shows 300uf for one and 305uf for other one ( that is in tolerance )..
                  ESR meter shows this.
                  So from what I can see they are good, not as new ones maybe, but not so bad, usable I would say.. What you other think ?
                  From that I desolder 4 in a row with 16V and 3300uf.
                  They are almost perfect.
                  ESR meter and capacitance test shows.
                  0.005 - 3270uf
                  0.009 - 3300uf
                  0.013 - 3340uf
                  0.009 - 3140uf
                  From here you can see what is desoldered.
                  I have two ones 2x 10V 3300uf next to this 4x 16V which I desolder, and other ones are very hard to reach under heatsinks.. but they are couple of them more there..
                  It is very very hard to work and from this point I don't know what to do next.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    That PSU looks much better than expected for Raidmax!
                    Albeit it's likely overrated in watts, wouldn't be surprised if the components are intended for 500W to maybe 750W.
                    Those caps, however, is worthy of being labeled a bronze-grade.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1865
                      Raidmax really picked up their game. I had a RX-500XT. While not a 500W unit by any means, it was a REALLY good 400W unit and had great layout. Just the main filtering needed some work as it was done by a bunch of monkeys (probably the same monkeys behind Youtube's servers)
                      Main rig:
                      Gigabyte B75M-D3H
                      Core i5-3470 3.60GHz
                      16GB DDR3-1600
                      Samsung SH-224AB DVD-RW
                      Delux MG760 case
                      • Zender
                        • Aug 2020
                        • 13
                        • EU
                        This PSU was very good and I have never problems with it..
                        At least I don't have problems at all now, only in games there are occasional restart, but for about 10 years old that is ok. It was always be used in desktop PC with one graphic card, so it has work about 30-40% of it's capabilities all time, but years have done their thing..
                        If anyone have idea what to try more, please advice.
                        • Zender
                          • Aug 2020
                          • 13
                          • EU
                          Re: Raidmax rx-1000ae PSU weaken - occasional reset
                          Yesterday I receive a replacement 420V caps..
                          I replaced Teapo with Nichicon 420V 330uf, but problem stay the same, I have bad PG signal, it is 190 and blinking sound of warnings..
                          In a meantime I found this : https://jestineyong.com/power-good-p...-power-supply/
                          Can anyone tell me where is this ''secondary side PWM IC'' in picture on my PSU ?
                            • Jul 2011
                            • 6023
                            Did you replace the capacitors that are under the heat sinks or did you just check them
                            • Zender
                              • Aug 2020
                              • 13
                              • EU
                              I check all caps on board and both ESR meter and capacity test show that all of them are OK.. I just order from China and replaced this big ones..
                              I don't think caps are problem here..
                              • odie34
                                Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                by odie34
                                I am a hobbyist (not a professional) so please be gentle...
                                I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                02-18-2024, 09:11 AM
                              • ictc
                                Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                by ictc
                                I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                02-25-2025, 12:15 PM
                              • kotel studios
                                ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
                                by kotel studios
                                Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
                                Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
                                I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
                                12-14-2024, 10:48 AM
                              • MyBrainIsAStrainer
                                Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                                by MyBrainIsAStrainer
                                Hi!
                                I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                                Symptoms in detail:
                                1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                                2. I press power button. The board boots without issues.
                                3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                                4. Push power button again, board boots fine.
                                5. This shutdown/powerup can be repeated multiple times without problems.
                                6. BUT: If I do a restart instead
                                06-25-2023, 02:44 PM
                              • masterm
                                JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                by masterm
                                TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                Problem with TV:
                                - Netflix stopped working so i tried to do factory reset from the TV menu.
                                - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                - After waiting for some time, the TV went into a boot loop.
                                - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                04-30-2024, 03:03 AM
