Fsp250-60hen
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Re: Fsp250-60hen
    I had a Hyundia car many years ago that I wanted to shoot. Didn't have to. It blew up all on its own.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
    • everell
      • Jan 2009
      • 1514
      Re: Fsp250-60hen
      I have POWMAX and DEER (L&C) that need the firing squad. But in looking a little closer at the pictures, this looks like an interesting power supply to study. I have three Sparkle FSP400-60GLC power supplies. I have spent some time playing with them and drawing schematics of whats inside. Compare the photos of the 400 watt version with the 250 watt psu here. Same basic layout, same SMALL heatsinks. This one has active PFC using two FETs instead of one. It also has 5vsb using DM311 pwm chip for RELIABLE 5vsb performance.
      For those who enjoy the engineering aspects of power supply design, I will include my "crude" schematics to give you an idea of whats inside.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        Re: Fsp250-60hen
        I do believe that is the FSP Epsilon platform. They are good up until about 500W, after that the ripple starts to get out of spec.
        • everell
          • Jan 2009
          • 1514
          Re: Fsp250-60hen
          Today I got a OCZ Technology 850 watt power supply. Model is OCZGXS850. But the pc board marking tells the true story. It is a FSP850-80GLN. It uses the same 5vsb transformer and driver transformer as my 400 watter. The main switching transformer looks about the same size, but has a different part number. Here are some pictures of it, including a side by side of the 850 watter and the 400 watter. Notice the similarity of the component layout.
          I don't know if it will actually do 850 watts anymore than 400 watts for the other. But I am now thinking that the 250 watter at the beginning of the post is using the same pattern, and is probably MUCH better than the PowMax and Deer power supplies. So what do you think???
          On the 850 watter, notice how SMALL the output capacitors are!
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Re: Fsp250-60hen
            http://www.overclock3d.net/reviews/p...850w_atx_psu/6
            Take that one with a large grain of salt. I can't really find any real reputable review site with one, but they claim they have a custom built tester for power supplies and they put it under a 886W load. But those voltage regulation numbers look a little too good. These FSP builds aren't that good of performers. No scope shots either, and these platforms aren't known for well controlled ripple at higher wattages.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              Re: Fsp250-60hen
              I fully agree, it is a way better design than deer powersupplies
              However as I don't have a scope to check the ripple I could not really fix it (it was killing harddrives)
              However the other scope we used worked fine on it
              • everell
                • Jan 2009
                • 1514
                Re: Fsp250-60hen
                The emachines with the Bestec ATX-250 12E killed the mother board, hard drive, and everything. So as you can see, your Fortron 250 watter was a much better power supply. It only killed hard drives!
                Most of the power in the 850 watter is for the +12 volt output, so my take on the problem is that you were putting too much load on the +12 volt rail when using that 250 watt power supply. How many hard drives did you have attached to it???
                • POM_MJ
                  • Aug 2009
                  • 228
                  #28
                  Re: Fsp250-60hen
                  Wow, the harddrives killer was born!.
                  | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                  | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                  | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #29
                    Re: Fsp250-60hen
                    Not my system, it was some Gateway or similar shit that killed it's original PSU, got this thing under warranty
                    Get this, it had a Q6600 too
                    Now I know about power consumption of computers, that Q6600 wont be pulling 250w on the DC side
                    So in the end it was too crappy of a PSU
                    Most likely due to the heatsinks, i.e. when it got loaded like 80% or so the switching transistors probably became too hot so they could not deliver a stable current for the computer
                    Harddrives are the most sensitive components inside a computer, they really can't handle a poorly filtered current
                    This PSU would have needed bigger heatsinks, bigger primary capacitor and bigger secondary capacitors, plus there are some empty spots on the secondary too...
                    • everell
                      • Jan 2009
                      • 1514
                      Re: Fsp250-60hen
                      This series of power supplies has Active Power Factor Correction. That means it was a 250 watt psu MINUS the power consumed by the APFC circuit. So with APFC it was a more efficient power supply........more efficient at killing hard drives!!!
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        Re: Fsp250-60hen
                        everell; no, the 250w rating is at the secondary side, it does not involve the primary.
                        I.e. with a 250w power rating at the secondary and an efficiency rating of say 80% it would be pulling ca 300w on the primary side
                        Plus with APFC the primary capacitor is run at a higher voltage, so you get more energy storage. (Power stored = capacitance times voltage squared.)
                        You must remember that without PFC or APFC the reactive load causes heating of the compenents aswell, the APFC reduces this heating (heating = power loss) so infact the APFC offsets some of the PSU's other components efficiency loss due to the reduction in the reactive load.
                        Atleast that's my understanding of PFC
                        • everell
                          • Jan 2009
                          • 1514
                          Re: Fsp250-60hen
                          This PSU would have needed bigger heatsinks........
                          If your theory about less heat with APFC is true, then this power supply having smaller heat sinks should have been acceptable.
                          Look at a psu without APFC. You only see TWO heat sinks. With APFC, such as this power supply, you see THREE heat sinks. The third heat sink is for the FET and diode in the APFC circuit. So if APFC reduces heat, then you should be able to remove that third heat sink. Try it and see what happens!!!
                          Generating enough heat to require the EXTRA heat sink means additional power is being consumed. Is that extra power part of the 250 watt rating? How can you be sure that it isn't......maybe just more marketing hype. Can you believe and have confidence in the labels put on these power supplies???
                          A power supply with a true 250 watt output should have been plenty for that computer. The power supply we are talking about is labeled 250 watts and has APF correction. So it IS more efficient. It more efficiently blows out hard drives.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #33
                            Re: Fsp250-60hen
                            Scroll up and you will see me saying what this PSU needs to be decent to begin with is bigger heatsinks
                            Umm, I said that APFC reduces the heating caused by reactive loading (poor PFC) in the other components, i.e. that it moves that heat loss into the APFC circuit instead, and that doing this probably slighly offsets the reduction of efficiency that APFC causes
                            Why the hell do you think we shot it into pieces, because it was a decent powersupply well worth saving?
                            • manuelw
                              Re: Fsp250-60hen
                              its very easyyy:
                              you can buy new one directly from pc-macedonia at pc-macedonia.com
                              http://pc-macedonia.com/products/B41...wer-Supply-PSU
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                Re: Fsp250-60hen
                                manuelw; You are over 2 years late to the party but welcome to Badcaps.net
                                I would never buy this PSU new though, €30 is very expensive for target practice
                                • everell
                                  • Jan 2009
                                  • 1514
                                  Re: Fsp250-60hen
                                  Oh Deer.......................
                                  Perhaps 2 years late, but those pictures were classic - glad he resurrected them.
                                  I spent a lot of time fixing and documenting that FSP platform. But in the end, what I put in my computer was a "fixed" Bestec ATX-250 12E. It does not blow hard drives, it does not blow the mother board, and it keeps on going..............
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #37
                                    Re: Fsp250-60hen
                                    It's been very interesting following your PSU rebuild threads.
                                    Especially the 5vsb modifications
                                      Re: Fsp250-60hen
                                      Sometimes APFC is moved onto the other heatsinks, so you can have just two heatsinks. Having three isn't a requirement for APFC.
                                      APFC produces more heat and makes PSU less efficient, but it often turns out to be cheaper than non-PFC for >150W nowadays, especially necessary if you want to sell it in Europe.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #39
                                        Re: Fsp250-60hen
                                        I'm reviving the thread because I got an FSP250-60HEN for free!
                                        When I got it, it was full of dust. But it's still working!
                                        The APFC heatsink is the thinnest heatsink I have seen in an ATX power supply! The other 2 heatsinks look bad too.
                                        When designing this power supply, great effort has been made to cut costs. As a result, the PCB uses just 2 screws to be secured on metal case
                                        The secondary heatsink is screwed to the metal case of the psu and thermal paste has been used, turning the psu case to a huge heatsink!
                                        The primary capacitor is Teapo 100uF 400V. This is a value you could expect in laptop power adapters, not ATX psus rated for 250W!
                                        The capacitors are a selection of Teapo SY, Capxon KF and OST RLP. Guess what! The Teapo and OST caps look fine, while all the Capxon caps are bulging. This adds to what I'm claiming for years, that Capxon are awful and should not be considered on par with Teapo, OST, Samxon, Taicon and other non-Japanese caps.
                                        I would like to fix this psu, because it has some positive aspects one cannot ignore:
                                        -250W unit with APFC
                                        -MBR3060CT for 12V
                                        -It is indeed a dual 12V rail psu. 12V output has 3 caps and 2 coils. The coils are used for filtering and current limiting.
                                        -Main transformer and 5vsb transformer are of proper size.
                                        -5vsb generated with DM311 IC, so it's not going to cook your motherboard.
                                        pdavid already experimented with this platform before:
                                        https://www.badcaps.net/forum/showth...ghlight=fsp250
                                        What do you think?
                                        • Stefan Payne
                                          • 1267
                                          Re: Fsp250-60hen
                                          why??
                                          when 270uF is sensible for 400W and 180uF for 300-350W, then 100uF for 250W seems logical.
                                          You make one mistake:
                                          Look at the Series Charts of the manufacturers.
                                          Teapo SY is some mid range one.
                                          Capxon KF is the worst they have to offer. GL seems to be much much better (and reliable)
                                          What really would help if we had the prices of the caps from the manufacturer directly...
                                          If we had that info, we could better assume the quality...
                                          My guess would be that CapXon KF might be a bit cheaper than even Teapo SC...
                                          Well, those seem to explode from time to time...
