Recommended Low ESR Caps Brand / series for PSU?
  • smile
    ICC ProfileGuru
    • Feb 2013
    • 120
    • Lithuania
    Hello, what are current recommended series for replacing bad capacitors in todays PSU?
    Panasonic
    nichicon
    samwha
    Please list series too, as companies make too many variants.
    • 31214
    Re: Recommended Low ESR Caps Brand / series for PSU?
    it depends on your location,
    in the u.k. for example, panasonic FR are really cheap.
    in the u.s. people often prefer chemicon and nichicon because *they* get better prices on them.
    samwha is not on the list of prefered caps btw,
    i would use panasonic FR followed by rubycon ZL*
    • smile
      ICC ProfileGuru
      • Feb 2013
      • 120
      • Lithuania
      I'm from EU, Lithuania. Most corrupt EU country whose government will put china to it's place .
      I would like to buy from Poland or any other country in European Union.
      Also why caps are available in 500pcs boxes
      https://www.rutronik24.com/category/...by:price/vn:16
      https://www.tme.eu/lt/en/details/uvy...tors/nichicon/
      Are shops trying to kill themselves by not selling like they used to by 5 or 10pcs?
      Or are they getting ready to bankrupt?
        • 31214
        tme is good,
        it looks like they are low on stock though.
        nato bullshit is causing chaos AND huge price rises.
        i was looking at solder yesterday, a reel i got last year for €28 is now over €38 +VAT
        bastards.
        • smile
          ICC ProfileGuru
          • Feb 2013
          • 120
          • Lithuania
          Searched for 220uF 16V cap on tme, and seems they have none.
          https://www.tme.eu/lt/en/katalog/105...0%3A1438173%3B
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It is hard to make such a general recommendation:
            It will depend allot on the PSU design.
            A more expensive and well designed PSU might use really low ESR capacitors.
            While a cheaper one would not run well or at all with such capacitors...
            Best is to check what is there originally and then stay quite close to that in ESR.
            • smile
              ICC ProfileGuru
              • Feb 2013
              • 120
              • Lithuania
              Yes that is exactly what I did with my MOBO, but that takes too much time and now even is impossible if you are not going to buy caps in bulk boxes 500pcs, 1000pcs.
                master hoarder
                • May 2008
                • 12175
                Perhaps try contacting member Behemot? He sells smaller quantities and has a good variety selection.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
