I need help identifying the issue with my Magnavox MDR513H dvd recorder!
  • gilbert009
    grizzly
    • Mar 2021
    • 6
    Hello! I am fairly new at repairing electronics. Recently I came across an old Magnavox MDR513H dvd/hdd recorder. It is not powering on. When the unit is plugged in, I get this really annoying beeping sound coming from the power supply.. I have already tried things like unplugging the unit for a few hours, holding the power button for a minute or 2. Nothing seems to make It work.
    I found this guy with the same problem on YouTube -https://www.youtube.com/watch?v=iFVm-SJX-S8
    I checked all over this video's comments but no one really helps him with the issue. except for one comment that seemed legit. (screenshot of the comment is attached.)
    if the guy in the comment is correct. I have no idea on how to test this zenner diode to see if mine is indeed bad.
    I would appreciate if somebody helped me on how to test it. or maybe somebody knows where I can get a replacement for me to see if this is the issue. I have no idea on the zenner diode specs or how to look it up.
    zenner diode markings are 1N4755A A20
  • lotas
    • Jan 2016
    • 4598
    • Russia
    Re: I need help identifying the issue with my Magnavox MDR513H dvd recorder!
    1n4755a - 43v 1w
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      if it isnt shorted or open its likely ok .. only way of testing is with a power supply and resistor and voltmeter .. could of course simply test in circuit .
      • R_J
        • 9535
        If that is D2229 it is a 1N4755A zener diode (43v 1watt) on the EV+33v supply. If it is not shorted it is likely ok. Check it with your meter.
        Must be some tech that it took him 8 months to find a shorted zener diode. 3 other shops couldn't find it? If the smps is squealing it is usually caused by a short in the secondary, the first thing to check would be the zener protection diodes.
        And the likey cause is the elec. capacitor on that line going bad causing the voltage to increase due to not filtering the high frequency ripple.
        • gilbert009
          grizzly
          • Mar 2021
          • 6
          Thanks for your help everybody ! Sorry for my lack of knowledge. but what should the zener be reading while in circuit? also what mode should I test it in?
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            if one end goes to ground it should have its rated voltage right across it . but only if its good and the supply to it is working like it should .. first see if its shorted .
            • R_J
              • 9535
              The zener diode can be checked out of circuit with your meter in either diode mode or on the lower resistance scale, it could also have been checked in circuit.
              Also check D2213 and D2215, these are also zener protection diodes on that board.
              Using diode mode the reading across the diode should be .6xx one way and open circuit the other way.
              • Akuanka
                Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                by Akuanka
                I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                Thanks in advance for your help!
                11-23-2024, 01:12 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
