FSP150-50LG Fault
  • jarenfeldt
    • Sep 2012
    • DK
    FSP150-50LG Fault
    Hello
    I have a FSP150-50LG PC power supply where the 3.3 and 12v is missing.
    Is there anyone who have schematic for this PSU or know where the fault is
    Thanks 🙂
  • everell
    • Jan 2009
    • 1514
    Re: FSP150-50LG Fault
    The Bestec ATX250-12E is a great power supply IF you modify the 5VSB. The IMicro power supplies are also great power supplies IF you finish putting in all the parts that are supposed to be there. But the low power FSP power supplies are hard drive blowers. I have seen only one fix for them, as can be seen in the pictures. Not sure what size rifle bullet permanently fixed this hard drive blower.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Rooz told me it was caliber .243
      ^^There you go
      As fun as that picture is I just want to say that today I have a scope, back then I didn't and that was the reason back then for not touching it.
      That and the end-user suspected the PSU, so how would I know if I made it better or worse after a recap?
      You may remember the article on the now defunct Jonnyguru where they had that experience...
      I mean the poor PoS has Capxon capacitors, what do you expect?
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        meh its a waste of rifle bullets. its not even worth the cost of the bullets used to shoot at it. just wire it up to short circuit and use it as a hand grenade. some icute and other junk brand power supplies are exactly just that. a hand grenade waiting to blow up!
        • everell
          • Jan 2009
          • 1514
          jarenfeldt: I know these posts so far have not been very helpful, but I was hoping to add a little humor to the repair process. Given enough time and money, any power supply can be fixed!
          First, it would be more sociable to know what country, city, and state you are from.
          Second, it would be most helpful to see some pictures of the power supply you are trying to repair.
          And finally what information can you give as to what troubleshooting you have done. You mentioned, no 12 volts and no 3.3 volts. I would start by measuring the main fuse. Is it open? Is the 115 VAC/230 VAC switch in the correct position for the line voltage you are using? When powered up, do you get any voltage on the 5VSB rail? If not, you won't get much of anything. Do you get any voltage on the 5 volt rail? These are things you need to start with. So let us know what you have.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            ^ I 2nd what everell said above.
            Basically, we'd need more info and pictures to dig in further.
            There may be schematics somewhere on the internet (perhaps some Russian website), but I generally never look for such, as I find I waste too much time looking at irrelevant pages. It's quicker to do the troubleshooting yourself sometimes (and perhaps with the help of a forum like BCN ) than to waddle through websites that make it look like they have schematics for everything, but really have none and just echoed your search engine query on their site to get a hit.
            ^^There you go
            Oh I remember that one now with how the wire came out all mangled from the main traffo where it hit. On the other hand, I see the 5VSB traffo survived. I could certainly use one of those right now for a PSU I'm repairing. (well, I already used one out of another junk PSU, but differences in the pri. aux. windings aren't supplying enough voltage for the PWM of the main PS to work... otherwise, I did get the 5VSB running on that 2-tranny circuit without blowing up a single part! )
            Nah, not worth even that, IMO. Too many useful parts even the lowest-end junkers to justify smashing/blowing/destroying one. So I save *every* PSU I come across... but given my title, that's to be expected now, isn't it. Of course, the really bad ones I just don't use in a PC and may use for parts only.
            • everell
              • Jan 2009
              • 1514
              [QUOTE=jarenfeldt;
              I have a FSP150-50LG PC power supply where the 3.3 and 12v is missing.[/QUOTE]
              Whereas there has been no followup on this power supply, I hope you can bear with me with a little humor.
              The picture here is a FSP power supply in which the 3.3 and 12v is "missing"!
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • iMic
                Vintage AT Power Supplies - Selecting Capacitors
                by iMic
                Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                02-19-2023, 06:45 PM
                09-06-2024, 05:59 AM
                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 02:15 PM
                HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                09-07-2024, 05:20 AM
