Repair or part it?
  • technicalspecialist
    • Jun 2010
    • 65
    Re: Repair or part it?
    Whats are captive power cables? I've never heard that term before.
    Do you just mean the IEC plugs/sockets (aka kettle leads) that are commonly used on computer PSUs?
    http://mindmachine.co.uk/products/IEC_Connectors.html
    If it's broken, fix it. If it's not broken, improve it.
      • 31214
      captive power cables are cables you cant remove.
      like on cheap shit dvd players & tv's where it just goes through a rubber block to save the cost of a connector.
        • Jun 2010
        • 65
        Oh yeah, I don't like that either but it depends on the device.
        But i'd certainly be really annoyed too if I'd just bought a 50inch plasma and it had a fixed power cable (most likely 3 core).
        But usually it's low power stuff like DVD players, set top DTV boxes, etc... that don't need an earth wire. My denon AV amp has a 2 wire fixed (captive) power cable but I don't really mind too much as it's always stayed in the same place.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i wouldn't care.. if it broke, soldering time!
          sigpic
          (Insert witty quote here)
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • Yanleb
            Panasonic part number in service manuals
            by Yanleb
            In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
            This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
            For an example, look at the attached PDF.
            Do you have a way to cross reference the Panasonic part number with the actual part number?
            Thanks....
            07-03-2023, 08:16 PM
          • FreakyMex
            Trouble to identify part (Lunii screen) for replacement
            by FreakyMex
            Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
            I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
            02-17-2025, 01:16 AM
          • esinior
            Smd code to part number
            by esinior
            Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
            I've attached pics of this part
            Thanks...
            08-20-2024, 02:50 AM
