Repair or part it?
  • Colt45ws
    • Jan 2009
    • 174
    Repair or part it?
    Its a "VAV" 300W that I used in my home server for 3..or 4 years. Which is a Duron on a K7S5A (no 12V). It only got a UPS a couple months before I replaced it. It was still running fine, or so I thought until I opened it.
    Input caps are "Viva" 680uF @ 200V
    Outputs are mostly viva also. 3x 3300uf 10V and a single 3300uF 16V. All these are blown. I cant tell what the little ones are as far as rating, but they are a mix of Capxon, and Jun Fu.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Repair or part it?
    part it. the heatsinks are too small, as are the filtering caps. but, on the bright side, lots of good parts:
    2 x caps
    choke
    bridge rectifier
    coils (if you dare to try removing them...
    there is no way one could get 300w out of that thing.
    sigpic
    (Insert witty quote here)
    • Colt45ws
      • Jan 2009
      • 174
      Thats what I was leaning towards..
      The part number in the middle says 240ATX...hmm wonder what that means. :P
        master hoarder
        • May 2008
        • 12164
        That's one ancient Deer/L&C power supply! Probably the most well-built Deer I've seen from that era.
        If you're intending to repair it so that you can use it in the same home server, it should be okay for that. Couple of things to point out, though: by now, most (if not all) of the caps are probably toast (particularly the Viva ones). Unless you have an ESR meter to verify them, replace everything down to the smallest ones. Even the two big 200v ones are probably bad so get them too. Also, the big, low-ohm resistors on the secondary side seem to produce quite a lot of heat. You might want to remove them after you put the new caps (should you repiar it, that is).
        Actually it might do 300 watts. Main transformer is of good size, and if you look at the 3rd picture, you'll see that the primary transistors are big enough for the job too. The heatsinks are okay.
          master hoarder
          • May 2008
          • 12164
          Double-post, sorry. 10-minute edit limit got me ...
          So, to answer the question in your title, I guess that depends up to you. New caps for this PSU might cost more than usuall (since it's likely that you will have to replace the 200v ones) and chances are that you can probably find a decent PSU for a similar price. But if you just want to fix this PSU for fun, then it should be okay as Deer PSUs are usually reliable with good caps.
          • Colt45ws
            • Jan 2009
            • 174
            I think this was purchased around..I want to say '00.
            I stripped it of anything that looked semi usable. The only thing I recognized is the bridge rectifier, which has part # PBU605 on it.
            I got a couple coils off it.
            I also got a yellow square thing that has HQX and 0.33uF 250V on it..
            2x 2SC2625
            1x BYQ28E
            1x KA7805
            1x C3150
            1x S30D40C
            1x SBL2040 PT
              • 30934
              keep the power inlet connector.
              i use them on all the stuff i get with captive power cables.
              i fucking hate captive power cables!!!
              • Colt45ws
                • Jan 2009
                • 174
                I did keep it. I tossed it into my box of useful junk.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  2x 2SC2625
                  1x BYQ28E
                  1x KA7805
                  1x C3150
                  1x S30D40C
                  1x SBL2040 PT
                  I'm fairly certain it could do 300W. Looks like you parted it out already. Did you throw it away yet? I was wondering if you could get the transformer out of it. I might be able to use it in my deer.
                  Also, the two little things in shrink wrap next to the primary caps are MOV's, take those too.
                  • Colt45ws
                    • Jan 2009
                    • 174
                    Maybe. The big main one?
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Yup, the one that says ERL-35 CD on it.
                      Part out all the parts of the input filter, all the X caps (the yellow squares,) Y caps (blue ceramic type caps,) and coils. I would also take out things like the pi filters. I usually keep the PCB's around in case I need some little resistor or something for a different psu. All these things are useful when fixing other psu's.
                      • Colt45ws
                        • Jan 2009
                        • 174
                        I got the transformer.
                        I also just burned myself bad because for some reason I grabbed the hot end to put it away since I thought it was unplugged for the last 2 hours... It was not.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Ow. I've done that with a cheapie soldering iron, but haven't dared to with my 599 C hakko.
                          • Colt45ws
                            • Jan 2009
                            • 174
                            • etnietering
                              • Apr 2009
                              • 379
                              That's a decent sized transformer. Very nice
                              On a somewhat related note - I've never grabbed a hot soldering iron, but one time in chemistry class my friend picked up a Bunsen burner immediately after turning it off. It burned almost his entire palm. I had a good laugh about that one hehehe
                              And I'd say hang on to the whole thing - you never know when something from it will come in handy.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Yup thats the right transformer all right. A real 35 sized one too.
                                  master hoarder
                                  • May 2008
                                  • 12164
                                  Colt45ws, I have a question for you... Do you know what C25 is in your PSU (i.e. what voltage and uF rating)? I have a Deer PSU that is very similar to yours, but on mine that cap was blown to pieces when I got it (only its leads were remaining). Seems like a common failure too as I saw another old L&C here with the same cap blown. Here's the post actually:
                                  https://www.badcaps.net/forum/showpo...&postcount=254
                                  Cap should be near the PWM controller on the secondary side. Thanks.
                                  • smason
                                    • 1652
                                    No kidding. My new Samsung 50" Plasma has a captive cable. I was pi$$ed when I saw that.
                                    • Colt45ws
                                      • Jan 2009
                                      • 174
                                      C25 is a 47uF 50V part.
                                        master hoarder
                                        • May 2008
                                        • 12164
                                        Much appriciated, thanks. I might revive mine some day just for the sake of it. I'm particularly interested to see that 5vsb circuit in action - it's self-oscilating with no feedback and produces ~15v. KA7805 then regulates that output to 5v for the 5vsb.
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • G-Sting
                                          iPad Pro A1876 SHORT Part Identify Help Needed
                                          by G-Sting
                                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                          SO My main concern is what part should i order what should i search the name for ?
                                          on Ipad...
                                          05-15-2025, 09:30 AM
                                        • Yanleb
                                          Panasonic part number in service manuals
                                          by Yanleb
                                          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                          For an example, look at the attached PDF.
                                          Do you have a way to cross reference the Panasonic part number with the actual part number?
                                          Thanks....
                                          07-03-2023, 08:16 PM
                                        • FreakyMex
                                          Trouble to identify part (Lunii screen) for replacement
                                          by FreakyMex
                                          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                          02-17-2025, 01:16 AM
                                        • esinior
                                          Smd code to part number
                                          by esinior
                                          Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                          I've attached pics of this part
                                          Thanks...
                                          08-20-2024, 02:50 AM
