Identifaction of SMPS IC in Lidl parkside Charger PLCP-016A
  • alltvrepairs
    • Jan 2014
    • 239
    • Malta
    I am trying to rebuilt this charger after the output diodes shorted and eventually blew the primary side of the SMPS. I need to know the part number of the IC.
    Model:PLCP-016A charger from the PARKSIDE drill set.
    Parts faulty: R7, R8, R9, R10 all 1R5.
    MOSFET transistor HF4N60,
    IC1 marking on IC is 01G12 -- need this part number.
    Thanks!
  • arsharpe
    Hitachi drill charger UC18YKL
    by arsharpe
    I am fixing the charger (UC18YKL) for a Hitachi battery drill (DV18DCL2) but, as it charges Lithium batteries, I need to know the correct replacement device for the blown (smd) FET2.
    As I have spent many hours trying to find a schematic for this DV18DCL2 charger without any luck, does anyone know where I can get one or a parts list?
    Thanks in advance for any help,
    Rob
    07-12-2025, 11:53 AM
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
