EVGA NEX650G power supply detecting a fault on startup.
  • nikload
    • May 2020
    • Соединенные Шта&
    Re: EVGA NEX650G power supply detecting a fault on startup.
    good evening
    A similar problem
    replaced R76 10 om
    Worked for 5 days and burned out
      master hoarder
      • May 2008
      • 12170
      Originally posted by nikload
      good evening
      A similar problem
      replaced R76 10 om
      Hmmm.... that suggests nothing is majorly wrong in there if the PSU can work "OK" for a while. But since the same resistor has burned again, perhaps some component somewhere has drifted in value and is causing an overload on that resistor. Or maybe the design was marginal to begin with and so that resistor just burns out after a while when components start to drift in values from age.
      OR OR
      Maybe there's an intermittent ceramic cap somewhere shorting out... though I don't see how that could happen with the same cap in two different PSUs.
      Another possibility is the output CapXon caps going bad (high capacitance perhaps?) It would be interesting to see someone actually check the ESR and capacitance of the output caps to see what exactly is going on.
      And if not, perhaps the easiest solution would be to use a big (1 Watt?), through-hole 10-Ohm resistor for R76 and see what happens then. Will the PSU still burn it or will the PSU burn itself?
      Given how majorly over-cooked the trace looks in the picture in post #5, I honestly wouldn't suggest trying a resistor rated for bigger power. IMO, that's the same as using a fuse that's larger than what the application calls for... and typically the results can be lots of smoke and sparks when something fails.
      • kuntao
        • Mar 2021
        • Philippines
        what is the code of Q29
        • kuntao
          • Mar 2021
          • Philippines
          that is a 10 ohm resistor
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 660
            • samsara
            I just destroyed one of these that had the same symptoms
            Finally, Q29... it also appears to be either a free-wheeling or forward rectifying device for the 5V rail (thus equivalent in function to either Q3 or Q4 in Figure 1 on the FPS article linked above.) Obviously if Q26 is one, then Q29 will be the other and vice versa. But again, I see a minor error here in the table - pin1 (Gate?) of Q29 shows as reading "1.92" to the 5V rail. I'm pretty darn sure this measurement is not in Ohms. If it really is, that may be a problem. But I really think you're using the continuity/diode test mode here and not resistance as I asked... so I can't actually tell if the reading is problematic or not. Also, when stating the resistances, please state the units too. I don't mean to make this into a high school science class all over again . But clearly "1.92" doesn't really mean much without units. If it's Ohms, that's no good for sure. If it's KiloOhms or MegaOhms, then it's a completely different story.
            ​After a lot of effort getting the large toroid off, i saw that the gate of 031N03L (Q29) goes to one of those 2R0 resistors, and then to that through-hole dot, then through the board and onto the top side of the board to a trace that goes to through-hole dot that is between the two mosfets (G26, Q27), which are connected to both big square pads, which are connected to the 5V rail
            So it looks like the gate of Q29 is meant to be connected to the 5V rail via a 2R0 resistor
            Gate Q29 ----- 2R0 ----- 5V rail
            Seems a bit odd, since in that FSP schematic all of the gates are connected to a controller chip
            Underneath that 14-pin 6601 chip, it looks like some components got hot - the smd caps either side of the resistor aren't shorted and the resistor doesn't give a stable resistance
            Didn't notice that till after though
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 660
              • samsara
              #26
              So it looks like it's probably the same fault
              I've put it back together and will order replacement mosfets, and then try using a 10 ohm resistor (post #24)
              The output caps tested good ESR and resistance (couldn't read two of them because i pulled out the leads when removing them)
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 660
                • samsara
                #27
                Working good now
                Except the 10K resistor heats up to more than 100 °C
                Couple of youtube vids of folk replacing this resistor that had obviously burned out due to to excessive current, but they failed to check the temperature
                Over 1M ohm at the resistor to ground, and the only other path that's connected to the resistor (except for the SMD caps and the FSP chip pin) is a diode that has 47K ohm to ground on it's other end.
                This diode (D1) is biased for current flow into the resistor and then into the FSP 6601 chip
                Maybe there is something wrong with the chip
                12V at the positive side of the diode
                There is -485mV across the diode, and there is +15mV across the resistor with conventional current going into the FSP chip (both components are in series, and test leads orientated the same way along the trace)
                I=V/R, so current through the resistor = 0.015/10 = 0.0015 amps
                Something's not right there, as i don't think that that amount of current will cause the resistor to heat up to over 100 °C
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 660
                  • samsara
                  #28
                  Checked the voltages at either side of the diode:
                  12.15V at the cathode, and about 11.6V at the anode
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 660
                    • samsara
                    #29
                    Checked the temperature of the chip, the pin of the chip that's connected to the 10 ohm resistor, and the PCB near the resistor; but the resistor is the hottest.
                    How can a resistor heat up like that with such a small current?
                      master hoarder
                      • May 2008
                      • 12170
                      #30
                      Maybe there's a large AC current across it? Tried measuring the AC voltage? Probably going to be a bit tricky too with just a regular multimeter, as any high frequency may not be measured correctly, depending on the meter.
                      Me thinks this needs to be looked over with an oscilloscope (if you have one.)
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 660
                        • samsara
                        #31
                        Thanks for you suggestion,
                        Yes, that did cross my mind.
                        I have a scope
                        ... and thought that that might be a good option, but wasn't sure about it, so decided not to, since i don't want a high voltage to damage the scope
                        Also i may have tried connecting a multimeter on AC, and didn't see significant voltage; so that might have discouraged me?
                        Now the PSU as gone back to the fan briefly spinning... but now with an additional short, mouse-type, squeak that's coming from the main transformer 😠 (used a small rubber hose to pinpoint the area)
                        I checked the rectifying diodes that are on the secondary heatsink, and one that isn't, and didn't find any shorts
                        The SMD diode, that's next to the 10K ohm resistor, is in series with it, and it's not shorted
                        I connected the scope to the side of the 10K ohm resistor (that is also connected to pin 13 of the 14-pin chip) and it has a steady 4V DC on it when the PSU is on standby
                        When the PSU is powered up, the scope briefly displays a well-defined, 1ms (1KHz), triangular waveform /| /| /| ... that has troughs at 4V, and peaks at 10V
                        I guess that i will have to take it out of the case again and check the other side of the resistor (between the resistor and the SMD diode), so as to find the voltage that's being dropped across it.
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 660
                          • samsara
                          #32
                          Was checking the other side of the 10K ohm resistor AC with a multimeter and was just about going to connect the scope, but before that i powered on the PSU few times and one of those mosfets blew up with a bang and a spark.
                          Talk about Murphy's law...Twice!
                          I took a chance, and replaced the mosfet
                          (The mosfet that's next to it looks damaged, but that was just some surface damage that happened when i was removing it earlier on)
                          So now after checking with a scope on both sides of the resistor...
                          the side that is connected to the chip displays an /| /| /| waveform, of which the peak is about 2V higher than when the probe is connected to the diode side
                          I think that if there was high AC current that was going through the 10 Kohm resistor it's no longer present because the PSU is now shutting down straight away, whereas before it wasn't, so it's not enough time.
                          If the main transformer squeaks, does that possibly indicate excessive current?
                          • socketa
                            Asbelowsoabove
                            • Jun 2014
                            • 660
                            • samsara
                            #33
                            3.3V and 5V rails are shorted to ground,
                            so that's probably what's causing the transformer to squeak
                            also, testing across all four mosfets, in circuit, that are on the back of the PCB, the drain and source are all shorted to ground
                            • socketa
                              Asbelowsoabove
                              • Jun 2014
                              • 660
                              • samsara
                              #34
                              Q27 and Q28 were shorted D-S,
                              which placed shorts across the other two non-shorted mosfets Q26 and Q29
                              Additionally, after removing the solder and disconnecting a leg, it looks like one of the rectifying diodes is open, as i get no response from it on multimeter diode test mode - this connects to the 5V rail via a 2 Ohm resistor, which, as mentioned before, is unexpectedly connected to the gate of Q29.
                              Neither he gate of Q29, nor it's series 2 Ohm resistor, are connected to any of the pins of the 6601 FSP controller chip
                              • socketa
                                Asbelowsoabove
                                • Jun 2014
                                • 660
                                • samsara
                                #35
                                Ripped off a trace and pads when removing the transformer to get to what i thought were two heatsink-mounted diodes, but they were mosfets that had their third leg soldered to the heat sink
                                They both tested good as mosfets
                                Board's very bent
                                Over it...
                                It's now a parts PSU now
                                Maybe someone can add to this topic if they make any further progress with one of these
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                  07-01-2024, 06:34 AM
                                • madan1
                                  555 based power supply getting too hot
                                  by madan1
                                  Good day.
                                  I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                  The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                  After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                  When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                  06-23-2025, 04:38 PM
                                • Andreas_de
                                  Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                  by Andreas_de
                                  Hello!
                                  i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                  Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                  Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                  04-12-2025, 10:38 AM
