Dell J728N 2700w UPS-Battery disconnected
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Hi .Can anyone help me about this UPS please.
    It wasn't any problem on it before customer said.He just left it on the side for couple of
    months.After they replaced batteries for following use.
    now it says" battery disconnected" alarm #199.
    Batteries voltage is 106v
    charge level level goes up.Thank you.
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Re: Dell J728N 2700w UPS-Battery disconnected
    Battery voltage in the menu is 60v 13% goes up.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      wait and see how high it goes .
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        it has 8x12v batteries . best check voltage on each one
        • djems3
          • Nov 2014
          • 32
          • United Kingdom
          Battery pack has 106v.Every battery have 13.24-13.27 volts
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            check the fuses and see if there is a reset procedure
            • djems3
              • Nov 2014
              • 32
              • United Kingdom
              When i start outputs in 3-5 sek. start " Alarm #28 DC link Over voltage"
              • djems3
                • Nov 2014
                • 32
                • United Kingdom
                All fuses are ok.I've done reset of alarms and factory reset.
                • djems3
                  • Nov 2014
                  • 32
                  • United Kingdom
                  Does someone has schematic for this model or any similar please.Thank you.
                  • djems3
                    • Nov 2014
                    • 32
                    • United Kingdom
                    Thank you Petehall347 for your answer.I've done it. Problem was broken way between
                    R17 and R18 because of moisture.
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      i guess it became a fuse .
                      • djems3
                        • Nov 2014
                        • 32
                        • United Kingdom
                        NO broken path between them.Broken connection because of corrosion .From
                        this resistors reading battery voltage R17-R18 and R27-R28.
                        • carrzkiss
                          Cyberpower cps1500avr not charging batteries
                          by carrzkiss
                          Hello, all.
                          Cyberpower Battery Backup Unit.
                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                          Checking the voltage, it was down to 22v.
                          I quickly removed everything...
                          06-15-2024, 02:10 PM
                        • master3112
                          by master3112
                          07-29-2025, 01:55 PM
                        • F R 2568
                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                          by F R 2568
                          Hello all,
                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                          If the laptop is only connected to the AC adapter (battery removed):
                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                          The power/battery...
                          01-08-2025, 05:45 AM
                        • diamon
                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                          by diamon
                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                          Pictures of these boards:
                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                          Dell...
                          02-28-2024, 12:51 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
