Dell J728N 2700w UPS-Battery disconnected
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Hi .Can anyone help me about this UPS please.
    It wasn't any problem on it before customer said.He just left it on the side for couple of
    months.After they replaced batteries for following use.
    now it says" battery disconnected" alarm #199.
    Batteries voltage is 106v
    charge level level goes up.Thank you.
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Re: Dell J728N 2700w UPS-Battery disconnected
    Battery voltage in the menu is 60v 13% goes up.
    • petehall347
      • Jan 2015
      • 4451
      • United Kingdom
      wait and see how high it goes .
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        it has 8x12v batteries . best check voltage on each one
        • djems3
          • Nov 2014
          • 32
          • United Kingdom
          Battery pack has 106v.Every battery have 13.24-13.27 volts
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            check the fuses and see if there is a reset procedure
            • djems3
              • Nov 2014
              • 32
              • United Kingdom
              When i start outputs in 3-5 sek. start " Alarm #28 DC link Over voltage"
              • djems3
                • Nov 2014
                • 32
                • United Kingdom
                All fuses are ok.I've done reset of alarms and factory reset.
                • djems3
                  • Nov 2014
                  • 32
                  • United Kingdom
                  Does someone has schematic for this model or any similar please.Thank you.
                  • djems3
                    • Nov 2014
                    • 32
                    • United Kingdom
                    Thank you Petehall347 for your answer.I've done it. Problem was broken way between
                    R17 and R18 because of moisture.
                    • petehall347
                      • Jan 2015
                      • 4451
                      • United Kingdom
                      i guess it became a fuse .
                      • djems3
                        • Nov 2014
                        • 32
                        • United Kingdom
                        NO broken path between them.Broken connection because of corrosion .From
                        this resistors reading battery voltage R17-R18 and R27-R28.
                        • carrzkiss
                          Cyberpower cps1500avr not charging batteries
                          by carrzkiss
                          Hello, all.
                          Cyberpower Battery Backup Unit.
                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                          Checking the voltage, it was down to 22v.
                          I quickly removed everything...
                          06-15-2024, 02:10 PM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • master3112
                          by master3112
                          07-29-2025, 01:55 PM
                          Dell Thunderbolt Firmware
                          by SMDFlea
                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                          The SKU is in brackets (****)
                          EDIT: NVM65...
                          01-26-2025, 06:22 AM
                        • dell_sadness
                          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                          by dell_sadness
                          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                          Have extracted the BIN and want to know how to rebuild a clean BIOS
                          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                          11-12-2025, 02:54 PM
