I'm trying to modify this psu (Diamond 500w)
  • forza764
    • Jan 2010
    • 26
    Hi, my father gave me this psu as a gift and after opening it, i found that is missing some filtering coils in the input and output. I have some coils and caps from dead psus to put in, but i can't because there is a resistor blocking the space for the input coil and one of the pi coils that should be in the secondary.
    My question is ¿is ok to remove the resistors and put the coils in?
    The psu has about 6 months of light use, and it still works, i just wanna improve it for learning and maybe use it as a backup.
  • etnietering
    • Apr 2009
    • 379
    Re: I'm trying to modify this psu (Diamond 500w)
    For the input side, the power supply will still work fine without this resistor. It's just a bleeder resistor to drain the EMI filter caps when the PSU is unplugged. Without it, if the AC is unplugged at the peak of the wave, these caps could sit with ~140 (or 280) volts on them, which would hurt if you touched them. It would be best to see if you can get the filter coil to fit in over the top of it, but if not then it should be fine to remove the resistor.
    For the output side, you should be able to just stick the coil in anyways, over the top of the resistor. From the picture, it looks like the resistor isn't covering the holes for the coil. If the coil isn't sitting flush to the PCB that's not a problem. If you really want to remove it though, you'll need to check what it's connected to. If it's just a simple load resistor from 3.3v to ground, then it's probably OK to remove (but the voltage might not be stable at very little or no load). However, if it's connected to something else it's important and should not be removed.
    Other than that - make sure you install the bridge rectifier properly (+ to + and - to -), and make sure to watch the voltages on the output caps. Also, be sure the coils in the input filter match the silkscreen on the PCB, otherwise you will end up with at best a blown fuse. Good luck! Be sure to post more pictures when you're done.
      • 30930
      put the resistor on the other side of the board.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        If you want some more work and have some solder wick or a good solder sucker, you can replace the secondary side rectifiers. I circled them in the picture I attached, as well as the missing 3.3v choke. What psu's did you get these parts out of? You can try taking the rectifiers off those too and use them to beef this one up. I usually beef up the secondary rectifiers so that if anything blows it will be the primary switchers, and if they blow they almost always won't take the attached hardware.
        • forza764
          • Jan 2010
          • 26
          Ok, i soldered the bridge rectifier, the input coil, x cap, and the pi coils. The caps haven't been replaced because i want to test it first, maybe tommorrow.
          Some of the parts came from a dead ISO psu, the primary was shorted, lots of burned traces, and now its missing a lots of components, hehe.
          For the secondary i have two MBR3045, but the holes spacing is too small for those rectifiers, any ideas?
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            MBR3045's are, simply enough, 30A, 45V schottky's (voltage acts the same like on a cap, operates up to that voltage). The 5v rectifier currently installed is probably the same thing. Sounds like they are the same package as the current 5v, a to-247 package or maybe a to-3p. Either way, there is 2 things you can do. Carefully bend the legs in to fit the holes (I've done this before with success,) or you can order some to-220 higher amperage schottky's, which would be more expensive (I would just ship you some of mine, but shipping would be a problem...)
            If you have more X caps you can salvage, put another directly on the AC receptacle, as 1 .1uf is not really enough. A higher value one like a .33uf or .47uf would do better. Replace the .1uf with a higher value one too if you have one that would fit.
            • forza764
              • Jan 2010
              • 26
              I have another question, after installing the bridge rectifier, ¿the mains selector switch is unaffected in function? here in Vzla the mains is 115v.
              • gramph
                • Mar 2009
                umm dont replace the 3.3v rectifier because it's actually not a rectifier but it's a mosfet. It takes power from 5v and regulates it to 3.3v.
                You can only replace with another similar mosfet.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  gramph-
                  I was afraid of this. Couldn't get a clear reading of the part number, but I believe you are right, this would account for the absence of the 3.3v choke as the mosfet cleans up the 5v into 3.3v and it creates a lot less ripple. Also the absence of the Mag-Amp coil near the primary transformer. Typically this indicates a very cheap adaptation of a AT psu to a ATX psu.
                  Forza764, can you please post the part number on the 3.3v rectifier, I have seen many cheap designs that use even a 40A mosfet here which would not need replacing.
                  As for the voltage selector switch, it still needs it. If you removed it, the psu would be stuck in 230V. If you short the two wires, it will be stuck in 115v. The only time they don't need a voltage selector switch is if they are Active PFC (Passive PFC still requires it,) or they have a special little daughter board with a circuit that detects and automatically changes the voltage setting. (though the only psu I have seen with that is my 450W ATNG)
                  • forza764
                    • Jan 2010
                    • 26
                    The part for the 3.3v is CET CEP3120
                    For the 5v i think is a S30140C, not sure, hard to read.
                    For the 12v is a Mospec F16C20C.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Yep, its a 30V, 40A mosfet, so no need to replace. IIRC, this is not only a cheaper way of doing it, but also more efficient.
                      Bad news, 12V rectifier is only a 16A, 20V schottky. Try and replace it with one of the 30A, 45V's you salvaged out of the other psu's.
                      The 5v rectifier is a 30A, 40V part. If you really wanted to over do it, the 5v is typically silkscreened for two schottky's. You could try and put those two identical MBR3045's in there, and replace the 12v's with the 5v's old schottky. Problem is two to-247's are very thick, the original screw for the 5v is probably not long enough to go through both.
                      BTW, you have some pretty good soldering.
                      • forza764
                        • Jan 2010
                        • 26
                        Secondary ready, and installed.
                        I will test it tomorrow, if it works ok, im gonna recap and change to a bigger case that comes with a on/off switch, the original doesn't have a switch and the 5vsb is always on, thing that i dont like.
                          • 30930
                          add an led for the 5v standby - that's always nice.
                          a 330 or 470 ohm resistor will be good for driving an led from 5v.
                          • POM_MJ
                            • Aug 2009
                            • 228
                            12V recitifier F16C20 is 16A 200V Fast Recovery type, not Schottky.
                            if you replace it with xxA 45V Schottky diode, it might be short immediately after powered ON because of breakdown by higher reverse voltage.
                            you might need to replace with xxA 60V Schottky diode.
                            | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                            | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                            | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              It should be fine. I have replaced many of the 200V Fast recovery type's in these cheap design psu's with 45V-60V, should be fine.
                              • forza764
                                • Jan 2010
                                • 26
                                Bad news.
                                I tested it and the +5vsb reads 5.0 volts, but when i try to start it, the only thing it does is a tick sound and nothing happens.
                                I used for load an old cd-rom drive.
                                • POM_MJ
                                  • Aug 2009
                                  • 228
                                  change 12V rectifier as I said.
                                    • 30930
                                    tick = safety-shutdown because of a short or overload.
                                    • forza764
                                      • Jan 2010
                                      • 26
                                      Ok i removed the MBR3045 and reinstalled the Mospec F16C20C, but the psu still doesn't want to turn on, i checked for shorts and i can't find any.
                                      Any suggestions?
                                      • POM_MJ
                                        • Aug 2009
                                        • 228
                                        restore all original rectifier parts, if the PSU still doesn't turn ON, problem might happened with main transistor switcher.
                                        • Salvador Pérez
                                          Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                                          by Salvador Pérez
                                          Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                                          • 0.91V for the GPU
                                          • 1.7V for VRAM
                                          • 3.3V and 5V rails 1.8V for the BIOS
                                          • 0.9V for the CPU and iGPU 1.2V for the RAM
                                          However, these two coils are not showing any voltage....
                                          03-10-2025, 11:50 AM
                                        • caspian
                                          How can I modify An EC firmware?
                                          by caspian
                                          Dear members,
                                          I have an HP Elitebook 2540P laptop with mainboard: LA-5251P REV 1.0
                                          It has a SIO with model: SMSC KBC1098
                                          I think both the EC firmware and the main Bios reside in a single Bios chip.
                                          Problem: KBC1098 is partially defective so that it does not generate ADP_En at Pin 75 and generates 8 amber blinks on the charging LED, indicating some wrong input.
                                          Idea: Now I need to modify the EC firmware so that KBC1098 ignores the wrong input conditions and always generates a high ADP_En and does not enter a failure state.
                                          Is it possible...
                                          05-21-2024, 01:35 PM
                                        • hexdy
                                          Modify BIOS to non-uefi
                                          by hexdy
                                          Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                          05-14-2024, 10:31 AM
                                        • ChanHa
                                          Help me Resistor on FSP Hexa ATX 500w
                                          by ChanHa
                                          My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
                                          06-04-2025, 08:44 PM
                                        • David Miteff
                                          NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                          by David Miteff
                                          Hello, guys!
                                          As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                          As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                          12-30-2024, 07:02 AM
