Mini Lenovo PC Dead Power supply (ACbell PCH018)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Mini Lenovo PC Dead Power supply (ACbell PCH018)
    You can simply power the PC with just a 12v supply (provided it can deliver enough current) and not bother with the green wire. It worked in my case. I assume if you have a normal ATX supply which requires turning on, you could short the green wire to GND permanently and use the 12v output to power the PC. This would also mean the fan on the PSU runs permanently !
    Alternatively, you could probably connect the after-market ATX to the PC "the right way" and make use of the green wire too to switch it on/off, but I haven't tested this to confirm, because it doesn't make sense for this to work as long as there's no STBY voltage - there would be no way for the PC to control the PSU. I imagine what the green wire does is toggle the original PSU between a full power and a low power state to keep power consumption as small as possible, despite the output always being on and fixed at 12v...this makes more sense, since there's no other STBY wire.
    Wattevah...
    • Cloggy
      • Dec 2021
      • 4
      • None
      Thanks to your tip I got it to work! It would be ideal if we could actually switch on/off the PSU with the motherboard.
      I actually just tried what you said and I put the PS_ON from my ATX power supply on the motherboard where the green wire of the PCH018 connects to the motherboard but there is no luck. Basically the PC doesn't start when I press the PWR_BTN.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Yes - makes sense, since there's no power going into the board at that point, so it can't "do" anything to that green wire...
        Wattevah...
          • Jul 2011
          • 6040
          One note on HP switching power supply you can not always get these power supply’s to work with out the the mother board hooked up sometimes it works but not constantly by this method so do not be surprised if you can not get it to work correctly this way for external power supply
          • Cloggy
            • Dec 2021
            • 4
            • None
            Thanks for the additional tips! I'm eager to continue diagnostics to get full ATX compatability.
            One of the things I'm considering is buying a DC-DC converter 5V to 12V to give the board the standby power it wants. However, it would have to do some switching as soon as the 12V line from the PSU comes on otherwise it shorts the +5V standby to 12V line through the HP motherboard.
            Any suggestions?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #26
              TBH, I'd just use a single 12v supply that's always on, as this is probably the only way of doing an aftermarket conversion on this PC - Meanwell works "Well" for this task Sure, if it has a fan, then you'll probably need some way to switching the fan on/off. You can do what I did and run the fan off the power connectors for the HDDs/CD, if the supply is always on by nature and the only way to get it to shut off is to kill its mains power. The MB, as far as I can tell, doesn't make use of an on/off signal pin (green) like traditional PCs do, or at least it doesn't use it in the same way, as there is no standby voltage present - I THINK it just toggles the PSU between a low power state and a high power state by adjusting it switching frequency or whatnot to make it "green"...just a theory.
              Wattevah...
                • Jul 2011
                • 6040
                One other note that if you decide to go that route you might get an error message that says that you have the wrong power supply when you first turn on the computer before you load windows
                • Andreas_de
                  Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                  by Andreas_de
                  Hello!
                  i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                  Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                  Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                  04-12-2025, 10:38 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • kevin_allein
                  Samsung QE 75 Q 7 FGMTZG Power Supply dead
                  by kevin_allein
                  Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                  In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                  Does anyone have schematics for that board ?
                  Any good tip, what could be the issue ?
                  02-27-2025, 12:15 PM
                • KYBOSH
                  Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                  by KYBOSH
                  I have a floodlight-security camera that recently died on me.
                  its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                  Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                  07-01-2024, 06:54 AM
