Mains inverters with 55 Hz output frequency
  • japlytic
    • Oct 2005
    • 2086
    On a generic box for a mains inverter I purchased, it had check boxes for the usual 50/60 Hz with an additional check box for 55 Hz - why would that particular frequency be offered at all?
  • petehall347
    • Jan 2015
    • 4451
    Re: Mains inverters with 55 Hz output frequency
    good question .. might be for the bass
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      If you're not sure, go halfway!
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
        MT3608 Step-Up Converter IC Datasheet
        The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
        Internal soft-start results in small inrush current and extends battery life.
        The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
        10-07-2024, 05:02 AM
        Corsair CX750M [Model 75-002019] - burned output toroid inductor
        by momaka
        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
        09-19-2021, 08:44 PM
      • CoppellTVRepair
        Troubleshooting PFC with SPC1012T not raising output
        by CoppellTVRepair
        It has been a long while since I posted here to ask anything....hope you can help.
        I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
        I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
        03-09-2025, 10:38 PM
