Tefal GV8962 Pro Express steam iron - no power
Re: Tefal GV8962 Pro Express steam iron - no power
Now about D3, what other bad components would cause the 2 solder points to read, with or without the D3, 30ohm both ways?Comment
Your pic #1 bottom right. TR2 looks like it is damaged a little on the top. What is printed on TR2?Comment
Yes, that was a very bad idea actually. In this case this resistor is a flame proof (green colour) resistor that is used a fusible resistor. Now you putting is there a 5W resistor, I am not sure if that is actually the only damage it did (blowing that 50V cap).Comment
Yes, valuable lesson learnt, thank you.Comment
The value of that fusible resistor will be likely be <10 Ohms.
https://ar.pinterest.com/pin/621848661029499082/Never stop learning
https://ar.pinterest.com/pin/621848661029499082/Comment
I moved one of the 2 relays, and here's a findings:
1) The pins (red arrow) reads 1569 ohm
2) I applied 12V, both directions, to these pins thinking it should click, but it does not.
3) The in-circuit relay also reads 1569 ohm, and also does not click when applied 12v to the coil pins.
Is this normal?
Next I removed the inductor L2:
1) I don't have DMM that read inductance, but resistance reads 1.8 ohm.
2) With L2 moved, D3 now reads correctly at 579 ohm in one direction only.
Does this means L2 is bad and shorted?Comment
The buck converter looks to be set up for 24V output, you can verify that by checking the value of the feedback resistor network , that is why the blown up C2 is rated at 50V, twice the operating Voltage.
I would not pull the relay out, you should concentrate on what component are connected to + lead of that filter cap C2. if you check the resistance between the two legs of the filter cap c2 solder pads, what do you get, 30 Ohms?Last edited by budm; 10-26-2020, 01:03 PM.Never stop learning
I trace out the relay driver, the buck converter is set to 24V for the relay coils.
Transistor T2 drives the relay REL1Never stop learning
With Inductor L2 removed, D3 measured correctly at 579 one way. When removed, it measured 30. Seems to by-passed to a shorted circuit somewhere?
-Comment
I would not pull the relay out, you should concentrate on what component are connected to + lead of that filter cap C2. if you check the resistance between the two legs of the filter cap c2 solder pads, what do you get, 30 Ohms?Comment
D3 is basically in parallel with the load through the Low DCR of the Buck inductor, that is why you see 30 Ohms when D3 is measure in the circuit, look at the circuit of the Buck converter then you will understand why.Never stop learning
I would have thought he had removed that blown up cap already since it is blown up, if not then I do not understand why it is not removed.Never stop learning
Not sure where to trace further...Comment
I decided to restore all the good and new components back into the PCB and do a basic continuity check - new 2W 100ohm R1 resistor, new 50v 100uF C2 capacitor, new U1 LNK304, and the original L2 inductor.
All pretty much the same, except now D3 now reads 579 in circuit.
I connect a 40W incandescent bulb between the Live wire of the incoming power. Power on - the incandescent bulb do not light up at all, the I measure to incoming voltage to the PCB - 243V.
But pressing the power button of the device - nothing happened, nothing blown, no led light.. Something component(s) blown opened?Comment
So now you are saying the resistance on C2 no longer show 30 Ohms?
Do you have 24Vdc on C2?
You also need to find out if you also have low Voltages to runs those IC or notNever stop learning
HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or RepairThis specification for the HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Tefal Daily Cook Saucepan Set boardview and 840 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
This specification for the HP EliteBook 1050 G1 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Tefal Daily Cook Saucepan Set boardview and 1050 G1 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
This specification for the HP ProBook 640 G4 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Tefal Daily Cook Saucepan Set boardview and 640 G4 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 09:00 AM
This specification for the HP ProBook 450 G6 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Tefal Daily Cook Saucepan Set boardview and 450 G6 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 09:00 AM
HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or RepairThis specification for the HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Tefal Daily Cook Saucepan Set boardview and 850 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 09:00 AM
- Loading...
