Tefal GV8962 Pro Express steam iron - no power
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8188
    Re: Tefal GV8962 Pro Express steam iron - no power
    Originally posted by beetle1303
    I bought a 1N4007 as replacement but have not soldered it in. I used back the original D3 diode, which was reading 576 off circuit in direction only.
    thats good, because the 1n4007 is too slow.
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      Now about D3, what other bad components would cause the 2 solder points to read, with or without the D3, 30ohm both ways?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8188
        Sorry, I don't get what you meant..
        TR2 reads 846 ohm one way between left and center pins, 793 reversed direction, and open in all other combinations.
        Your pic #1 bottom right. TR2 looks like it is damaged a little on the top. What is printed on TR2?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8188
          Yes, using this 5W 100ohm is bad idea.. I have gotten a 2W 100ohm to try out later.
          Yes, that was a very bad idea actually. In this case this resistor is a flame proof (green colour) resistor that is used a fusible resistor. Now you putting is there a 5W resistor, I am not sure if that is actually the only damage it did (blowing that 50V cap).
          • beetle1303
            • Jul 2019
            • 279
            • Singapore
            Z0103MA. There is some think there but don't seems to be cracked...
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #26
              Yes, valuable lesson learnt, thank you.
                The value of that fusible resistor will be likely be <10 Ohms.
                https://ar.pinterest.com/pin/621848661029499082/
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  #28
                  From this picture view - it seems like a 4-band resistor: Brown, ?, Brown, Gold. Brown, Black, Black, Gold gives 10 ohm, unless it's Black, Grey, Black, Gold to give 8 ohm?
                  • beetle1303
                    • Jul 2019
                    • 279
                    • Singapore
                    #29
                    I moved one of the 2 relays, and here's a findings:
                    1) The pins (red arrow) reads 1569 ohm
                    2) I applied 12V, both directions, to these pins thinking it should click, but it does not.
                    3) The in-circuit relay also reads 1569 ohm, and also does not click when applied 12v to the coil pins.
                    Is this normal?
                    Next I removed the inductor L2:
                    1) I don't have DMM that read inductance, but resistance reads 1.8 ohm.
                    2) With L2 moved, D3 now reads correctly at 579 ohm in one direction only.
                    Does this means L2 is bad and shorted?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8188
                      the first 2 pictures show a 24v relay not a 12v, the 3rd pic the inductor. The inductor should be ok showing 1.8 Ohms.
                        The buck converter looks to be set up for 24V output, you can verify that by checking the value of the feedback resistor network , that is why the blown up C2 is rated at 50V, twice the operating Voltage.
                        I would not pull the relay out, you should concentrate on what component are connected to + lead of that filter cap C2. if you check the resistance between the two legs of the filter cap c2 solder pads, what do you get, 30 Ohms?
                          I trace out the relay driver, the buck converter is set to 24V for the relay coils.
                          Transistor T2 drives the relay REL1
                          • beetle1303
                            • Jul 2019
                            • 279
                            • Singapore
                            #33
                            Arh.. silly me.. Yes, I applied 18v and it clicks, both off and in-circuit.
                            With Inductor L2 removed, D3 measured correctly at 579 one way. When removed, it measured 30. Seems to by-passed to a shorted circuit somewhere?
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              #34
                              Yes, both relays clicked when I applied 18v into them. And yes, the 2 solder pads of C2 reads 30 ohm.
                              • R_J
                                • Jun 2012
                                • 9551
                                Why don't you remove C2 and check it out of circuit, or remove it and check the solder pads to find out what is reading 30Ω
                                  D3 is basically in parallel with the load through the Low DCR of the Buck inductor, that is why you see 30 Ohms when D3 is measure in the circuit, look at the circuit of the Buck converter then you will understand why.
                                    I would have thought he had removed that blown up cap already since it is blown up, if not then I do not understand why it is not removed.
                                    • beetle1303
                                      • Jul 2019
                                      • 279
                                      • Singapore
                                      #38
                                      C2 already removed when it "exploded" on powered up.. but it still ready 89uF off circuit. The 2 solder pads between them ready 30ohm. I traced the +ve pad along the path to R31 and R31 read 120k ohm.
                                      Not sure where to trace further...
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #39
                                        I decided to restore all the good and new components back into the PCB and do a basic continuity check - new 2W 100ohm R1 resistor, new 50v 100uF C2 capacitor, new U1 LNK304, and the original L2 inductor.
                                        All pretty much the same, except now D3 now reads 579 in circuit.
                                        I connect a 40W incandescent bulb between the Live wire of the incoming power. Power on - the incandescent bulb do not light up at all, the I measure to incoming voltage to the PCB - 243V.
                                        But pressing the power button of the device - nothing happened, nothing blown, no led light.. Something component(s) blown opened?
                                          So now you are saying the resistance on C2 no longer show 30 Ohms?
                                          Do you have 24Vdc on C2?
                                          You also need to find out if you also have low Voltages to runs those IC or not
                                            HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Tefal Daily Cook Saucepan Set boardview and 840 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 09:00 AM
                                            HP EliteBook 1050 G1 + Tefal Daily Cook Saucepan Set Notebook 1000 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 1050 G1 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Tefal Daily Cook Saucepan Set boardview and 1050 G1 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            HP ProBook 640 G4 + Tefal Daily Cook Saucepan Set Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 640 G4 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Tefal Daily Cook Saucepan Set boardview and 640 G4 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            HP ProBook 450 G6 + Tefal Daily Cook Saucepan Set Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Tefal Daily Cook Saucepan Set boardview and 450 G6 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 850 G5 + Tefal Daily Cook Saucepan Set Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Tefal Daily Cook Saucepan Set boardview and 850 G5 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
