OKI 590 Dot Matrix Printer w bad power supply.
  • Jluxster
    • Jun 2019
    • 17
    Got this OKI ML-590 dot Matrix printer DOA with a note on it saying "no power".
    Sure enough. Does not power up. No lights, no startup sounds. I've ruled out the plug switch and fuses, no interlocks on the model that prevent power on. The PS is definitely getting power from the wall.
    Removed the cover and had a good listen. No noise of any kind from the power supply, and no bulging caps (though perhaps one of you Jedi masters can spot one the photos are good resolution).
    On closer examination I see some charring below a set of three light blue components on the top of one of the boards. There are also some charred looking resistors on this same part of the board.
    Any thoughts on what's wrong with this board and wether swapping a few components would put me back in business?
    Does the charring make this a lost cause?
    I think that's my issue, but I'm not sure.
  • lti
    • May 2011
    • 2551
    Re: OKI 590 Dot Matrix Printer w bad power supply.
    Those three blue components are also resistors.
    The black stuff on the smaller resistors and the back of the board looks like electrolyte leaking out of the nearby caps. You will probably have to replace all of the brown Nichicon caps and clean the board. There could be other problems as well.
      • 31065
      yea, caps have all leaked out onto nearby parts
      • Jluxster
        • Jun 2019
        • 17
        Hmmm.
        Any need to replace the resistors is that is the case?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Yes, the corrosion looks so bad that the legs might be corroded off.
          In any case if they are not now given a few years they eventually will...
          Electrolyte is some really corrosive stuff...
          P.S: The datecode of the caps shows they are 25 years old, so they don't owe anyone any favors anymore
            • 31065
            meter them to know your answer.
            • Jluxster
              • Jun 2019
              • 17
              Ok. So what I'm hearing is that the caps on that part of the board are the issue, and that I just need to check the resistors with my meter. That makes sense.
              In past PS repair, some times one blown cap meant many others blown downstream. Based on the part of the board this is, is that likely the case here?
              I'm trying to talk myself into bothering with the repair.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                The date code on the "C339" (LM339 clone) is late 1995. The Nichicon PL series is the pre-RoHS version of the current PM series and was introduced in the late 1980s, IIRC. Another clue to its age is the Marcon brand input capacitors. Marcon was bought by Nippon Chemi-Con quite a while ago. The output capacitors should probably be replaced due to their age, and the PM series would be the correct equivalent.
                Anyway, it uses a flyback topology, in which the primary of the "transformer" is actually a winding of a coupled inductor. The switch device is a MOSFET, 2SK1523 (Shindengen?). I see some very darkened PCB between the "transformer" and the MOSFET, so either some snubber components got very hot or there is a worse problem in the primary circuit. Check the input fuse, and if it is open, check to see if the MOSFET is shorted.
                If the P/S has a PWM controller (instead of being self-oscillating), check to see if the start-up capacitor (often ~47uF, 35V or 50V or ...). is OK. This gives the PWM enough energy to start up, but once started the PWM is powered by a winding on the "transformer".
                PeteS in CA
                • Jluxster
                  • Jun 2019
                  • 17
                  Anyone want to throw me a bone and identify the startup capacitor on my board?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    It is not possible to see it in your pictures.
                    Possibly it is IC101 that is the controller.
                      • Jul 2011
                      • 6040
                      One other clue it would probably be a capacitor is less than 200uf
                      But I would recommend replacing all the capacitors if I were doing this repair
                      You would have to look up the ic chip part numbers to find a chip that is either a switching power supply regulator or a PWM controller of some kind
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
                      • UglyBetty
                        Need some help with Epson Printer Power Supply C655 MAIN
                        by UglyBetty
                        Here is the back story. This printer had been sitting for about two years not used. I removed the print head to clean it (completely dried out). I cleaned it and reinstalled in. Powered the printer on, the printer started going through it's normal start-up procedure and part way through it was like the power just shut off. No sound, not lights, no error messages, it just went completely off. I suspect the power supply.
                        At any rate, the schematic for the power supply is included.
                        There is a lot going on on the low voltage side that I am not able to make heads or tails...
                        01-06-2022, 03:54 PM
