Newton NPS-160DB REBUILD
  • weirdlookinguy
    • Sep 2007
    • 1638
    Hey guys, I gave my brother my old 815G P4 motherboard a few months back and we built a decent little Windows 7 box out of it. As a result, I got to take his old computer, a 2002 Gateway nina-chassis P4 box and do as I pleased with it.
    I've always liked that little box, and it's slim, so I might be turning it into a media/backup/torrenting server or a media center machine. Now, about two years ago (IIRC), the proprietary Newton PSU in it broke. I swapped a few caps in there, and it went for a while longer, but then it broke completely. I got him an Antec basiq and we let it hang out the back of the case.
    Now the machine is mine, and I'm extremely anal about my electronics, so the ghetto PSU-hanging-out-the-back HAS TO GO. I looked in the old PSU, and I really don't want to try and fix it. I had no idea what the hell I was doing back then, so I did some pretty sloppy soldering, I scratched a few traces up pretty bad and had to run wire in their place, I destroyed some of the screws, etc, etc. So instead I found a working pull online for only $20:
    http://www.hypermicro.com/itemdesc.a...001997&eq=&Tp=
    These Newtons are VERY well built. Made in Thailand, Taicon primaries, Rubycon and Nichicon on the secondary with a few LTecs mixed in. Adda fan. Now, I looked it up, and apparently these PSUs are notorious for failure for seized fans.
    Wizard said not too long ago that Adda fans like to seize up. I didn't believe him. And now I found out that they apparently do. Lesson learned: LISTEN TO WIZARD!
    So what I want to do is to replace ALL the caps in it for Panny FC's, replace the Adda fan for a Nidec BETA SL, and resolder all the transformers and anything on a heatsink in there. This should leave me with a better-than-new PSU. Thoughts/feedback? Never really done anything like this before.
    Thanks,
    -weird
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Newton NPS-160DB REBUILD
    Newton is a subsidiary of delta. Typically they make the more proprietary form factor power supplies for delta, a lot of OEM stuff. Very good power supplies.
    With delta's soldering I would not expect you to have to resolder anything. As far as the fan goes, I believe nidec is probalby the best fan company out there, I have yet to ever see a seized one.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Yes, Newtons are usually very good.
      Fan plan sounds good.
      Spec the old caps first to make sure FC is adequate.
      Mann-Made Global Warming.
      - Dr Seuss
      • weirdlookinguy
        • Sep 2007
        • 1638
        That would explain the Delta-labeled transformer in it.
        When the (new and untampered-with) PSU comes in, I'll post the cap series and values.
        • weirdlookinguy
          • Sep 2007
          • 1638
          Looks like none of this will be necessary
          I got the PSU in from hypermicro today. It said on their page that it was a working pull, but there is no doubt in my mind that this thing is NEW. Nary a speck of dust on it, looks like it just rolled off the assembly line.
          The old PSU had a 2002 date code (obviously). This new one has a mid-2005 datecode. The old one is Revision 00, the new one is Revision 01. Nice.
          The old one made a quiet whining sound when the machine was in standby. It had done it since it was new in 2002. The new one is dead silent.
          The new one still has a mix of Rubys and Ltec, but no nichicon.
          The fan... drumroll... is a nice shiny SUNON. Which means no replacement necessary! So scrap the fan swap, its no longer necessary.
          It moves a fair amount of air, so I'm going to leave the mix of Rubycon and Ltec in there.
          I guess that makes this thread pretty much pointless, sorry guys! I wasn't expecting a new revision PSU.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Congrats!
            - Dr Seuss
            • Waffle85
              Fujitsu Lifebook E756 vPro Bios Repair/Rebuild help
              by Waffle85
              I got a Fujitsu Siemens Lifebook E756 vPro with a corrupted Bios after flashing. Device wont start anymore, only Blackscreen.
              Dumped the Bios and attached it. Maybe someone can help me repair/rebuild the bios?
              Thanks in advance...
              11-24-2023, 12:26 PM
            • mferna14
              Bin Files rebuild for HP Pavilion 17-cn1003ca
              by mferna14
              Hi, I am working on a hp 17-cn1003ca laptop., board # VLAD10-6050A3261101-MB-A01(A1).This laptop had gone to another repair shop & for no reason at all they just removed the BIOS chip (Chip missing). Checked the photo with identical board & no BIOS chip on mine & missing chip on these tracks. I downloaded the BIOS files from the Hp site for this model. The Model # is 17-cn1003ca & Serial # 5CG21832ZY. Can someone rebuild the Bin file for this Model & S.No. I have uploaded both, the 8MB & 16MB bin files, I think 16MB is required for this motherboard. Thanks in advance....
              09-12-2023, 09:18 PM
            • lap-top123
              Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
              by lap-top123
              HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
              Hp Elitebook 850 G8
              ProdID 52W98EC#ABD
              SN# 5CG1458XQ7
              Mac-address #1: 84:14:4D:2C:4B:5B
              UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
              Mainboard : 6050A3216701-MB-A01(A1)
              08-20-2025, 07:28 AM
            • IDElectroRep
              HP Pavilion 24-r111ne bios rebuild
              by IDElectroRep
              Hi
              I need help with a corrupted bios. The pc doesn't power on with the original file. I downloaded new file from HP and the pc works but I get the "Manufacturer setup" display. I would really apreciate if someone could help with adding the missing data from the original to the new file. Thank you!
              SN: 8CC8240QTT
              post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              05-07-2025, 10:28 AM
            • retrooo
              asus ga503q need bios rebuild asistence
              by retrooo
              good day to all, i have one asus ga503q that wont turn on only cps key blink for 3 seconds , i have one file from asus site but only gives me light on keyboard ,anyone can helpme to rebuild my original dump please
              any help will be appreciated
              thanks in advance...
              02-02-2023, 08:23 PM
