over voltage on power supply
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi guys, i have a Sony home theater which is currently on Protect mode, SD ERR code which is the power supply. I tested the voltages across the pins and its higher than rated. Suppose to be 14V but showing 20V instead, 6V showing as 9V instead. With or without load, its the same. Model is dav-dz840k. Any idea why this is happening? I have attached the service manual with this post. All the voltages seems bizarre on the power board while measuring.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Re: over voltage on power supply
    read page 18 on your SM
    • DjKrish
      • Oct 2012
      • 354
      • SG
      popped out the 1st cxd chip, problem solved. its a amp short. now unit is working fine. need to replace the faulty cxd chip.
      • DjKrish
        • Oct 2012
        • 354
        • SG
        CXD ic replaced and set working perfectly fine, looks like this is a very common problem with sony. Hope this helps others.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
          https://www.ebay.com/itm/116497313155?var=416785404161
          Here are some of the description from the eBay seller
          The main parameters:
          1. Product name: High-power non-isolated DC boost module power supply.
          2. Product model: 100A2000W.
          3. Input voltage: DC12V-60V.
          4. Input current: 100A (maximum)....
          05-18-2025, 09:45 AM
        • Jembang
          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
          by Jembang
          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
          11-01-2024, 09:55 AM
        • Green Probe
          Recapping a Denon AVR X6400h SMPS
          by Green Probe
          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
          Disclaimer: I'm an amateur hobbyist and will get things wrong.
          Always use caution when working around mains power and high voltage capacitors!
          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
          SYMPTOMS:
          -No display...
          07-18-2025, 03:36 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
