Samlex SEC-14 linear power supply 13.8VDC 10A repair
  • redwire
    • 3910
    Repairing a Samlex SEC-14 linear power supply, rated 13.8VDC "10-14A". Hong Kong company.
    Dumpster rescue, main pc board is RPS-1203 with two filter cap pc boards labelled RPS1220. The same control board is used in many of their models.
    The big 4,700uF Hangda electrolytics all took the piss, but no bulging as the bung has a vent.
    Inside I expected an LM723 but instead is a few transistors, couple 2N3055's and overall low tech. It's the cheapest power transformer, just loose windings no tape, a bit bigger than a MOT. No safety approvals. PC boards were riveted in.
    I drew a schematic and I'm not sure if this is worth five new caps ($15). No current limiting, so I can't use it for charging batteries and realistically it's good for ~6A continous due to the tiny heatsink.
    Part of me want to bin it. Any ideas? Or maybe I could get some low cost caps and use a TL431 or add current-limiting. Hmmm.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Samlex SEC-14 linear power supply 13.8VDC 10A repair
    At least it has short circuit protection...
    Also it should have fairly decent regulation (instead of just having a simple emitter follower regulator. No op amps or LM723 but it does appear to have worked around it well enough. No need to use a TL431 unless the zener broke.
    Adding current limiting would be good if the short circuit protection isn't sufficient.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      IMHO:
      The DNP capacitor should take the other 4.7mF capacitor on the control 22VDC rail, and that now depopulated 4.7mF capacitor can safely go down to 2.2mF. Perhaps this would be slightly cheaper to recap this way...
      Then again how bad are the caps barring the ones that spilled their guts? Capacitance? ESR?
      Wait...what the ... ? Are you sticking in low ESR 105°C caps in this? (Mouser seems to be more like $1.5/pop for bottom of barrel 60Hz 85°C GP caps, so less than $10 to recap the 5 caps...?)
      • redwire
        • 3910
        The power supply works- the capacitors are still alive. Not sure why it got thrown out, maybe it just stunk up the place I wouldn't run those caps, worried they would vent.
        Here are the capacitance and ESR readings. Note the AN8008 DMM is crap for testing electrolytic capacitors, the numbers are always useless from that Hycon single chip set- if there is any leakage current and these top out at maybe 1-2MEG ohms, it reads way high. Other numbers from Anatek Blue ESR meter and Amrel LCR meter, both of which I trust. Dissipation factor was high or infinity on most.
        The PSU has no current-limiting or short-circuit protection, no battery-charging protection diode, and I don't like any of that.
        It also has some strange AC mains fail/UVLO logic with the extra transistor which seems to latch off unless AC pulses are seen- but the diodes look wrong.
        Nowadays, you'd put in an RD Eng module.
        With the pandemic, my rule is to only use what parts I have lying around in the junkpile.
        I have a $5 0-30V 2mA-3A chinese kit power supply board, which ain't the greatest but if it can run on a center-tapped transformer, I might mod it to go to 10A and plop it in. I really like adjustable output current.
        I looked at new quality 4,700uF 35V caps (no need for low ESR here) Digikey is all around $CDN $3.00 each. From Aliexpress, including shipping around $1 each and like going to the casino.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yes it does have short circuit protection, you drew it. The "UVLO logic" indeed is short circuit protection. You probably can easily use that circuitry or even repurpose the components there to build a foldback current limiting, but yeah it will be some work if you want adjustable current limiting.
          And ah... $CDN funny money... now that makes sense... though you probably can get by with quality 25V capacitors.
          • zx8401
            Phantom Fiddler
            • Aug 2013
            • 49
            If it's anything like the other versions like the Altai/smart 2 ones, sometimes it won't start up and you have to treat it like a computer.
            Turn it off then back on again lol :-D
            Its the short circuit protection that causes it.
            The regulation is usually quite good :-)
            • redwire
              • 3910
              Yes it's the same weird protection circuit, sometimes you have to pull power and reboot. The protection transistor and error amp make a LATCH. It can throw you a curveball when troubleshooting.
              The protection transistor shuts off if the DC output dips below 4V, or there is no AC mains on startup. Either causes the error amp to LATCH full on. Once the error amp latches full on, it cuts off base-drive to the pass transistors and the power supply outputs nothing, and just sits there, forever.
              I did a LTSpice sim of the regulator to see how it works in cold weather, as I charge batteries outdoors in summer and winter. It varies from 13.8V 25°C/77°F to 14.1V at -30°C/-22°F. It's a good 4-tranny regulator but no real overcurrent protection.
              The main heatsink is tiny no way this puts out 10A without a fan.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I suspect if you're not charging batteries, SCP is sufficient instead of full current limiting -- if all you're doing is powering radios, just need to make sure you don't fry something when you short the output.
                At least each transistor only needs to dissipate half the full dissipation. Can't see the exact heatsink configuration (fin depth?) so no opinions here. Seems like a great find, I'd love to have one of these...
                Right now I'm using a repurposed/hacked XBox PSU as my radio PSU, theoretically it should also supply 10A (and likewise does not have current limiting/foldback). Still wonder if it was worth the effort to figure out how to get it to 13.8V, much easier to work with a through hole analog regulator... darn those SMT resistors. But as a SMPS it's so much lighter/smaller...
                • redwire
                  • 3910
                  chinese 2N3055's at their limit? If the pass transistors short, 22VDC will kill radio/battery etc.
                  At 10A, that is around 70W of heat... no way 8 fins 7/8" deep can pull off under 1°C/W rise. The back panel will help a bit.
                  So I was looking to add current-limiting to lower heat as a low car battery can easily pull 10A.
                  Adding the cheap 0-30V 2mA-3A PSU board with some mods looks like the way to go.
                  I find 12V SMPS can't do 13.8V without adding turns to the transformer, they max out to about 12.8V.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Do notice there's a 15V Zener crowbar there (you drew!). They at least tried.
                    If you're going to add a PSU board, you might well just drop all of the regulator circuitry and hook up the psu board straight to the main filter caps...
                    And might be true for forward, but how about flyback...
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • прямо
                      Help me understand this linear supply circuit.
                      by прямо
                      Was looking for a simple CV CC linear supply to build and came across this one.
                      https://oshwlab.com/svalentin544/lab...ply-0-38v-0-5a
                      I etched the provided board design and populated it.
                      The output voltage adjustment works.
                      The output current adjustment however, doesn't behave like I expected it to be. If PR2 is going clockwise, the output voltage decrease. Adjusting R5 has no effect.
                      I don't have a load connected to the output at all.
                      ​​​Can someone explain how the current adjustment work?...
                      02-17-2025, 11:09 PM
                    • sumilumi
                      700mv ripple on Akai Sampler linear supply
                      by sumilumi
                      Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
                      I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
                      On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
                      01-02-2022, 10:12 AM
