SMPS low voltage
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    SMPS low voltage
    I was repairing an SMPS that had failed. I managed to get it up and runing but t he main voltage rail is 1/3 less than what it is stated at around ~24.3V.
    I have marked the components I have replaced just in case with red dot, those with red and green have failed. All SMD components measure well.
    The amplifier also failed in this device, it is powered by the supply that now I have at low voltage. I have replaced amplifier hybrids and the same thing happens either way. With amp it is 22V with out it is 24V.
    I suspect LM3850 but I can not test it.
  • R_J
    • 9516
    Re: SMPS low voltage
    What is your line a/c voltage? 230vac? I suspect the pfc boost circuit is not working.
    What is the PFC_VCC voltage? It should be around 16~18v. You could have a bad electrolytic on the pfc_vcc line, CE521, CE520, CE513.
    Also check the source resistors on the pfc mosfet's
    • Sojke
      • Apr 2017
      • 131
      • Serbia
      Spot on, VCC was 10.7V.
      Now there is +32V , but no sound from amplifier, all outputs are at 16V (both + and - side on all channels). Without TAS5538 outputs are at 350mV (Like in working one I had). I exchanged it 3 times with new ones from China and same thing every time.....
      • C152Heavy
        by C152Heavy
        Summary for TL-DR readers:
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
      • ketone
        SMPS - Can they all handle wide range of Input Voltage?
        by ketone
        Hello Forum - See I got this SMPS Module!....its sourced from a US device and I'm in Australia.
        As we know Supply voltages in Australia 240v Versus 120V US.
        The Model of the SMPS is EAX39561401 and is used in LG and JVC DVD/VCR Player/Recorders...same model is used in both Australia and US...but perhaps they have differences??
        What's the chances I can use it in Australia - plugging it in to 240v instead of its origin country at 120v?
        Is it expected that most SMPS in such devices would handle between 100-240V by default?
        How can I...
        12-17-2022, 02:40 AM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        Yesterday, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        by sam_sam_sam
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
