For the tiny small uF caps, why do they use electrolytics?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    For the tiny 0.1uF-15uF range caps, why do they use electrolytics at all?
    - Why don't they just use ceramics? [Which don't dry out.]
    Brought up by larrymoencurly here:
    https://www.badcaps.net/forum/showpo...2&postcount=13
    I've been wondering the same thing and don't have a solid answer.
    A good enough question to deserve it's own thread so I moved it here.
    Mann-Made Global Warming.
    - Dr Seuss
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: For the tiny small uF caps, why do they use electrolytics?
    Could it be cost related?
    I'm not thinking of prices for a couple hundred caps
    But say you want 10 million caps for a production run, could you get a better price on electrolytics than ceramics?
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I think you probably nailed it.
      - I've always thought of ceramics as being cheaper but when the uF is the same as the lytic they just aren't.
      Looking at 1.0uF, Radial, 50v, +/-20% I found this:
      [Ceramics don't seem to have a 105c so I looked at 85c and 125c.]
      Cheap end of scale Ceramic [85c] -> $0.17360 each in qty 5000.
      http://search.digikey.com/scripts/Dk...me=478-2479-ND
      Cheap end of scale Ceramic [125c] -> around $0.60 each in 1000's quanities.
      Nuther note is the 1.0uF Ceramics leads are spaced 5mm or more, though with their shape they probably don't take much more PCB space.
      To compare, 1.0uF Panny FC - $0.04600 in qty 5000.
      http://search.digikey.com/scripts/Dk...name=P10312-ND
      So Ceramics are at least 3x more expensive even in bulk.
      I checked at 0.33uF too and it was the same.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        So NOW the questions are:
        Since they presumably only use lytics in those apps to save $$$$,,,,
        ,,,, are, and if so when are, ceramics a better choice for repairs?
        I probably knew this years ago, but my bung leaks.
        - Dr Seuss
        • Toasty
          • Jul 2007
          • 4171
          Maybe this will help?:
          http://my.execpc.com/~endlr/
          Or maybe it muddies the waters...?
          veritas odium parit
          • Harvey
            • Apr 2007
            • 264
            I always thought that
            High-K ceramics (Class 2 and higher) have poor electrical properties, which are highly dependent on temperature, voltage, and frequency, plus a significant aging rate.
            was the main reason.
            • Wizard
              • Mar 2008
              • 2296
              Correct. Ceramics is regarded as loose capacitance and varies in tolerance and temp, humidity as well.
              If you want precision and more stable, poly is way to go but bulk precludes these for need for space reasons.
              And bit of resistance in the electrolytic/polymer capacitors is desireable in many applications as well.
              Cheers, Wizard
              • larrymoencurly
                • Oct 2004
                • 960
                The FAQ there says: "I have no idea why someone would use a 0.1 uF electrolytic capacitor however."
                Of course in my Antec SmartPower IIs, those caps just happen to be Fuhjyyus.
                • everell
                  • Jan 2009
                  • 1514
                  My Antec SmartPower SP350 and SP400 also have Fuhjyyu .1 uF (and .22 uF) capacitors. So what did you do about this problem in your SmartPower II?
                  Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Those are usually on the fan board and from unit to unit I sometimes see ceramic disc caps there.
                    For under 10uF I usually just get these in 50v.
                    http://www.panasonic.com/industrial/...a_kg_02_02.pdf
                    They are mostly 4mm so fit anywhere and [under 10uF] they have better ripple than LXZ, FC, PW and all of those.
                    Digikey carries them.
                    - Dr Seuss
                      HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                      This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:44 PM
                      HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                      This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 03:36 PM
                      HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                      This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                      09-12-2024, 03:28 PM
                      HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
