Power supply broke
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Power supply broke
    Originally posted by prfcom
    Although I do have a limited supply of caps, I think I've probably wasted enough of my life on this P.O.S. which will probably end up in the garbage where it should have gone when it failed without any prior abnormalities
    This PSU doesn't look all that bad inside. I'd keep it for spare parts.
    Well, reading the post above, I guess you're done troubleshooting this power supply. But if you change your mind, I guess there's a few more things to try.
    Have you checked the power resistors on the primary side? By power resistors, I mean the big, low-ohm ones. Make sure one of them hasn't become opened.
    Also, if you hook up a multimeter to either 3.3/5/or 12v rail and you try to turn on the PSU, do they pulse for a second or no? If not then perhaps the controller on the primary side isn't getting a signal to turn on the FETs.
    I believe M2 and M8 are responsible for feedback from secondary side to primary side. Maybe a components somewhere in that circuit got open.
      by sam_sam_sam
      03-31-2024, 02:12 PM
      by sam_sam_sam
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • Andreas_de
      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
      by Andreas_de
      Hello!
      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
      04-12-2025, 10:38 AM
