Corsair GS800 Power Supply Problem
  • R_J
    replied
    Re: Corsair GS800 Power Supply Problem
    Check that the power supply is in standby when not connected to any pc. If the main power supply comes on before the ic sees a PS/ON signal the ic might not detect the voltage properly and give a false error
  • CapLeaker
    replied
    I think a valid PGI is more than 1.5V. I guess you have to trace that pin back.
  • R_J
    replied
    The power supply should not come on when there is nothing connected to it, if it does then something is telling one of the optocouplers to turn on the main primary supply I don't know which one it is but I suspect it is the one (U3?) just below the J22 letters. The other opto next to it is likely for feedback for the main supply, and the other optocoupler by itself, is feedback for the standby circuit.
    If the power supply is in standby there should be no +12v,+5v,+3.3v going to the WT7502
    The PSONB seems high, I would think it should be around +5v or less (the datasheet says max 7v)
  • ShortCircuited
    replied
    Probed the IC (WT7502) that provides PG signal. Does the problem look like an IC issue or a problem elsewhere? These values are from power on state-the only state I can get from the power supply (constant on) and green to ground no connection:
  • ShortCircuited
    replied
    PG is only .0873v
  • ShortCircuited
    replied
    Odd...Hooked to a 125watt desktop. Computer powers on instantly does not load windows and does not respond to the power button. PS acts as if it is in constant power on state. Voltages are all normal. Odd.
  • ShortCircuited
    replied
    very good find! keep my fingers crossed that it works after you reassembled it.
    You read my mind....will install and see and of course let you know what happens.
  • CapLeaker
    replied
    awesome!
  • ShortCircuited
    replied
    Preliminarily it works!!!!!!!
    Tremendous ty
    12.2v
    5.0v
    3.3
  • CapLeaker
    replied
  • ShortCircuited
    replied
    Originally posted by R_J
    Good find, BUT is the power supply going to work? lets hope so.
    Stop now while we are ahead...? Will post results in a few hours....
    Fixed break and we now have continuity across the primary winding as originally predicted.
  • R_J
    replied
  • ShortCircuited
    replied
    BINGO! Pin 5 (per post 33) has two wires and one is cracked/split. Looks like QC issue. The wire was not long enough during the manufacturing process and came up short it appears...so just add a glob of solder? Friday Build. I never would have found that without you guys. OH CANADA...!
  • CapLeaker
    replied
    an open primary would do it alright. As RJ already said, check the thermal fuse in the primary, if it has one.
  • ShortCircuited
    replied
    Check the primary winding to those pins that are cut off, I suspect there might be a thermal fuse in the primary. I marked where it might be, but it could also be between the other cutoff pin. check the resistance between those pins, the transformer might be fixable.
    You posted a picture of the secondary side, But post a similar picture of the PRIMARY side. I might be able to tell if there is an imbeded fuse
    Feedback Yellow: .78
    Primary Green: 1
    Thermal Fuse Red: open
    Might be here Blue: 1
    Primary Side:
  • R_J
    replied
  • ShortCircuited
    replied
    Solder joints look good. Primary winding is actually two wires whereas the feedback is only one wire.
    Curious. If I am getting .19 on the secondary side that suggests the primary winding broke early in the wind?
    Is it possible to fix this transformer? If i could find the opening a small bead of solder would be an acceptable fix? It appears the outside is glued together:
  • R_J
    replied
    Have a close look at the wires that connect to the pins, sometimes it can break right where it connects to the pin.
  • ShortCircuited
    replied
    When the original Q7 shorted it took the primary winding with it? Unfortunately, I don't think these transformers can be sourced reasonably cheap.
    Here is the suspect as oriented from the board bottom-view:
  • R_J
    replied
    Originally posted by ShortCircuited
    Feedback winding continuity.
    Primary open.
    Neg side of primary winding to feedback is 11 megaohm.
    That would do it. open primary
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
