APC BACKUPS-RS550 not charging battery
  • clearchris
    • Dec 2013
    • 687
    Re: APC BACKUPS-RS550 not charging battery
    If you left this idle for a year, it's likely your batteries are dead. Lead acid batteries do not take well to being left idle, just like in your car. I have a UPS that I'm not using at the moment, but I leave it plugged in. Best case is these batteries last 2-5 years when plugged in all the time. Dead UPS are always avaliable because the batteries go so quickly.
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Note that "leaving it plugged in" can result in the battery being cooked by the UPS (many UPSs don't flat the batteries properly) so that, when you actually NEED it, you find the battery is toast (and, likely "bulging" -- often to the point where you can't easily get it out of the case!)
      UPSs try to recharge batteries too quickly (and too cheaply!) on the premise that they may be "needed, again" in short order. It would be nice if the UPS could NOTICE the line conditions (i.e., how often there ARE outages and what their durations are) and adjust this policy accordingly.
      For example, if you encounter brief "power flickers", then the battery is carrying the load for really short periods so charging it "more gently" is likely not going to increase your risk of it being insufficiently charged to handle the NEXT flicker (this of course depends on the average interarrival times of those events -- but the UPS can determine that empirically!)
      Similarly, if the battery is deeply discharged by prolonged outages -- but they are infrequent -- then it can still opt for a gentler recharge (or, perhaps a quick influx of charge when power first returns but then switching to a slower charge rate to let the battery cool)
      • jinu_j
        • Feb 2016
        • 90
        • India
        I had swapped the old battery with a new battery. But the problem continued.
        • clearchris
          • Dec 2013
          • 687
          Did you check the date code on the "new" battery? Depending on where you get them from (don't get from amazon or ebay) they might not turn over quickly. Lead acid batteries go fast when they aren't hooked up to power...
          • Thorsten Freak
            • Dec 2021
            does anyone have a schematic drawing on 640-1172A-Z-REV05 printed circuit board an a APC Back-UPS PRO550?
            Mine isn't charging the Batteries properly
            cu Thorsten
            • redwire
              • 3910
              For your 550, I only find bits pieces here: https://www.elektroda.pl/rtvforum/topic3529704.html
              I have this schematic for APC 640-0259_REV05 which is I think is Back-UPS RS500, BR500i. No charging - electrolytic capacitor C7 22uF 16V usually bad. Check R28 runs very hot.
              It is unfortunately different, 550 using IC2 TYN278PN and some add-on TL4 board with two 22uF 400V for C12. IC2 does not need the usual 22-47uF cap there on pin 2 BP/M.
              • theone111
                • Mar 2022
                • 13
                • Israel
                #27
                I have a similar problem with an APC BR550GI Pro UPS
                https://www.se.com/il/en/product/BR5...ckups-pro-550/
                • theone111
                  • Mar 2022
                  • 13
                  • Israel
                  #28
                  cu Thorsten
                  Any luck finding and fixing? I have the same model and problem.
                  • elbass7
                    • Dec 2023
                    I have the APC BACKUPS 650 with a similar problem...however, it won't turn on the battery backup outlets, even with the unit connected to good 120VAC power. Just makes a ringing noise, which sounds like an inverter, but no power comes to the outlets. Only 3.45 volts are trying to charge a 12 volt battery. I took the battery out and charged it on my car charger on the slowest setting and it seems to hold a charge. After charging I can connect it to the UPS and with the unit unpluged from the wall, it make the same ringing noise. The green power light comes on, but pushing the on button does nothing.
                    Any help would be appreciated on next steps.
                    Eddy B
                    • redwire
                      • 3910
                      Start a new repair thread, your model is different.
                      Mods, I would move it
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Shinju
                        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                        by Shinju
                        Hey All!
                        Long time forum member here with a problematic laptop issue!
                        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                        The laptop would not power on with the new battery installed without the power supply being plugged in.
                        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                        10-20-2021, 04:58 PM
                      • Thomasraud
                        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                        by Thomasraud
                        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                        QUOTED
                        -It works on charger (without battery connected-only charger)
                        -It works on battery (without charger connected-only battery)
                        -& it also works when plugged in battery & charger, but it's not charging the battery
                        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                        and..
                        QUOTE
                        The IC cannot maintain the input current level
                        06-28-2022, 06:47 PM
                      • drlarsen
                        MacBook Air M1 A2337 battery/charging issue
                        by drlarsen
                        Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                        I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                        On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                        After some hours, the battery status did not improve. Restore via DFU did not help.
                        I connected the power adapter to a Kill-a-Watt...
                        07-17-2025, 02:35 PM
                      • abrahim110
                        [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                        by abrahim110
                        ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                        I have an Acer Aspire 5 A517-52G-53NB laptop.
                        The onboard (soldered) RAM was faulty, so I physically removed the chip.
                        I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                        โœ… System status:
                        • BIOS mod is done (SPD removed)
                        • Laptop boots to Windows normally
                        • RAM is detected and stable
                        โŒ Problem:
                        The battery is not charging:
                        • Power adapter
                        Today, 06:15 AM
