APC BACKUPS-RS550 not charging battery
  • jinu_j
    • Feb 2016
    • 90
    • India
    Hi Folks
    I have a APC BACKUPS-RS550. This was lying idle for over a year. Now when i checked it was not working (no power). Checked the battery and found it to be dead( zero Volts). So i replaced it with a new battery.
    Now it powers on and functions properly, but the battery does not charge so the UPS works till the battery voltage falls and then dies. I need to figure out why it is not charging. I checked the onboard fuses and it seems fine. The caps also dont seem to have any issues (atleast visually). can anyone help identify why it is failing to charge.
    The pic of the PCB is attached. Any adivce on how to troubleshoot the issue ?
    • Jul 2011
    • 6059
    Re: APC BACKUPS-RS550 not charging battery
    CAUTION you have line voltage at this section of this power supply so please be careful when taking voltage measurement ( 120 volts DC or higher )
    With out the battery installed
    First check the fuse just before the capacitors and ( IC7 )
    Also check to see if you have any voltage on those two capacitor if you have voltage on the capacitors
    ( then go to —> )
    Second
    Do you have voltage on ( C43 )
    If you do not have any voltage on ( C43 )
    Then replace the IC chip with the part number TYN274PN ( IC7 )
    Then go from there
    I do not see the start capacitor for this switching power regulator or then again some of them do not have one it does have one it is ( C45 )
    • jinu_j
      • Feb 2016
      • 90
      • India
      HI Sam
      Thanks for the guidance.
      All tests were conducted with the battery disconnected
      I checked the fuse F3 and that is fine, its not open
      There is voltage at the two capacitors (c50 and C51) about 165V each
      At C43 the behavior is very weird. when i disconnect the battery and check i see about 11.45V (which is same as the current battery voltage). So i short the terminals of the capcitor so that the capacitor discharges. Now when i check the voltage is near zero but very very gradually increasing at the rate of 5mV per second. Switching on or off the 230V mains has no impact on this behaviour. I cant understand how the voltage is increasing if the mains are off. After crossing 0.5V the rate at which voltage across the capacitor increases slows down further.
      So does this mean the IC is IC chip with the part number TYN274PN is bad ?? Any way to cross verify this ?
      Thanks once again
        • Jul 2011
        • 6059
        Probably I would just go ahead replace it
        It switching power regulator does not seem to be switching at all
        Here is the data sheet for this ic chip
        • jinu_j
          • Feb 2016
          • 90
          • India
          Ok will replace this and get back. What should the ideal voltage be at C43?
          BUt i still dont get it, the UPS works fine, and will move to battery power when the mains go off and go back to main power when the mains come back. The only problem is once the mains come back the battery does not charge. Is the above component part of the charging circuit ?
            • Jul 2011
            • 6059
            Yes this is the charging circuit
            • jinu_j
              • Feb 2016
              • 90
              • India
              Finally the replacement TYN274PN came in today and i changed in and it started working fine. Thanks a lot for your help.
                • Jul 2011
                • 6059
                One more item that did not make it to the land fill
                Good work on this repair
                • jinu_j
                  • Feb 2016
                  • 90
                  • India
                  Need more help. Now i got a same model UPS to repair again, but this time found both the Fuse F1 blown and the chip TYN274PN ( IC7 ) physically damaged (blown). Considering the UPS was used for PC in a factory of sorts, assumed a power surge or voltage fluctuation had taken both out. So i replaced both the fuse and the chip. Now i am back to the similar problem you helped fix last time. Works perfectly on AC current but does not charge the battery.
                  The fuse and IC7 are new (just replaced)
                  Voltage on each capacitor is about 165V
                  Voltage at C43 is about 1V
                  I also checked the voltage across capacitor - C48 (left hand side top of IC7), which is supposed to show the reference voltage of IC7 and that is showing 5.85V correctly.
                  The images post replacement of fuse and IC7 are attached. Any help point me in the right direction would help.
                    • Jul 2011
                    • 6059
                    Dose this battery backup have a separate transformer in the case
                    If you have track where the battery is suppose to get the power to charge the battery
                    Will the unit work if you have it plugged in and remove the plug does what you have plug in the battery backup stay working you do have to have charged up batteries to do this test
                    This is important that it will work in the backup mode because if not it might not be worth repairing it
                    • jinu_j
                      • Feb 2016
                      • 90
                      • India
                      Yes the UPS has a separate transformer in the case. The transformer input is J3 and J4. The output goes to J2. When the UPS is on backup (battery) power, the transformer kicks in and voltage at J3 j4 is about 8V as battery is weak (about 10V) and the voltage at J5 is 210V.
                      When on main power all the voltages at the transformer at zero.
                      The UPS works fine and switches to battery power when mains power is switched off and switches back to main power when main power returns.
                        • Jul 2011
                        • 6059
                        Do you have any voltage on U1 on the input side of it
                          Is this the actual model you have?
                          https://www.apc.com/shop/il/en/produ...rentSite=false
                          Can we the rest of the unit and the transformers?
                          I wonder if opto U1 is damaged when the TNY blew up.
                          • jinu_j
                            • Feb 2016
                            • 90
                            • India
                            Voltage across U1-OptoCoupler
                            Battery connected - With Mains power on but ups off
                            - Across pins 1 and 2 - zero
                            - Across pins 3 and 4 - 0.186V
                            Battery connected - With Mains power on but ups on
                            - Across pins 1 and 2 - 0.008V
                            Battery connected - With Mains power off but ups on backup power
                            - Across pins 1 and 2 - 1.157V
                            - Across pins 3 and 4 - 0V
                            The unit i have is described here. Its in Russian i think but google translate to convert to english
                              So it is RS500 as shown in Russian link? not RS550?
                              RS550 has display panel, but your board does not have any connector that goes to the display panel.
                              Show us the pictures of YOUR unit.
                              Your unit uses PCB 640-1115A REV. 06 as shown in your pictures and in Russian link.
                              • jinu_j
                                • Feb 2016
                                • 90
                                • India
                                No. It does not have a display panel. It is the RS-550 on my panel, but the circuit board is the same. Please see attachment for photo of front panel
                                  That is strange that your RS-550 does not have LCD diSplay: https://www.youtube.com/watch?v=hGR-JkgiN3I.
                                  From my research, the RS-550 uses PCB 640-1172A REV 05.
                                  But put that aside, I cannot find the schematic of the PCB 640-1115A_REV 06 used in the UPS that you have.
                                  I still suspect that opto-isolator is damaged when that TNY blew up.
                                  • jinu_j
                                    • Feb 2016
                                    • 90
                                    • India
                                    Same problem here searching for the schematic. I came across the Russian page when i was searching for the schematic. The only difference between the board mentioned on that page and my board is the REV number. Mine is REV 06, on the page it is REV 07
                                    Thanks. i will try replacing the Opto-Isolator. But I cant seem to the find the exact replacement part (A817V). Search for this leads to an equivalent HCPL-817.
                                    But there are so many variants of it, i dont know which one to pick. They differ primarily on the CTR value ranging between 50% to 300%. Not sure which one is compatible to the one on the board
                                      Look at page 3 of spec sheet, the rank code marking is on the bottom right of the body.
                                      You have A817V so body code is HCPL-817-06xE
                                      If the rank code is '0' then the CTR is 50 ~ 600%. = HCPL-817-060E
                                      If is marked an rank A = HCPL-817-06AE for CTR of 80 ~ 160%.
                                      BTW, did you remove the opto and then check resistance of the Photo transistor side and the Emitter side?
                                      • jinu_j
                                        • Feb 2016
                                        • 90
                                        • India
                                        I am finally giving up on this repair. The Opto was a surface mounted device. Its placed right next to the transformer which has a lot of plastic on it. In my speed to remove the Opto from the board before causing damage to the transformer from the hot air gun, I succeeded in ripping up the pads and track from the PCB for one of the legs. There does not seem to be a way to salvage the situation. :-)
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Shinju
                                          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                          by Shinju
                                          Hey All!
                                          Long time forum member here with a problematic laptop issue!
                                          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                          The laptop would not power on with the new battery installed without the power supply being plugged in.
                                          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                          10-20-2021, 04:58 PM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
                                        • abrahim110
                                          [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                                          by abrahim110
                                          ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                                          I have an Acer Aspire 5 A517-52G-53NB laptop.
                                          The onboard (soldered) RAM was faulty, so I physically removed the chip.
                                          I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                                          โœ… System status:
                                          • BIOS mod is done (SPD removed)
                                          • Laptop boots to Windows normally
                                          • RAM is detected and stable
                                          โŒ Problem:
                                          The battery is not charging:
                                          • Power adapter
                                          08-06-2025, 06:15 AM
