Corsair 750W SemiMOD
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Got an corsair 750w semi mod, which will not turn on ...
    Now I have 5VSB,The relay clicks when connectin it to 220V (with gren to black) ...
    But have no 12V,5V,3.3V, -12V ...
    All caps are ok,nothing seems to be burned (no smell, no brown place)
    The supply is CS750M ...
    Any advice,
    thx
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Corsair 750W SemiMOD
    More info about the PSU might help us be more helpful.
    Is the large electrolytic capacitor on the primary side rated for 400, 420, or 450 volts? If so, what is the voltage across it? If so and the voltage is around 390V, the PFC circuit is probably working, and the problem is probably with the PWM or inverter circuits.
    PeteS in CA
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      They are 400V and I have 340 on them DC ...
      It's a CM750M from corsair
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        Sorry CS750M from corsair ...
        Faound that Q103 i Q104 PNP transistors BCW69,BCW70 (H2P,H1F - board marks) ...
        Now :
        base - colector - 0.646V
        base - emiter - 0.660V
        with + on base ...
        base -colector - 1.047V
        base - emiter - 0.646V
        with - on base (that's for Q103)
        Q104 is behaving opposite the Q103 (switched + and -)
        D103,D104,D5,D6 both sides 0.004V ...
        ZD201 one side 0.707, other 2.45V ...
        ZD204 one side 0.725, other 1.197V ...
        D101,D102 both sides 0.660V ...
          master hoarder
          • May 2008
          • 12175
          That's normal for when the APFC is not running (i.e. PSU outputting only 5VSB).
          It's LOW for when the APFC >IS< running (i.e. when you try to turn ON the PSU). Should be around 375-385V DC. If not, the APFC is not switching properly - and that can be due to the APFC being faulty, due to the 5VSB being faulty (on the primary side), or due to the secondary side being faulty and telling the PSU not run.
          Pictures of your PSU would help us see what you are seeing. So if possible, please upload some.
          • llonen
            • Sep 2014
            • 495
            • hampshire
            I have had nothing but bad experiences with Corsair, and wont have anything to do with them after going through 4 of the things in 6 years. I find they have a habit of exploding so extra band for your buck. The end result were boards with large areas of copper tracking burnt of the substrate along with a number of un-identifiable burnt or exploded smd devices.
            I have had about a dozen of the things come through the workshop for repair mostly the 1200 watt ones with similar faults, few were repairable due to the extensive damage to the PCB substrate the majority of them I had to advise the customers were scrap. At the time they were in excess of £200 with a service life that just made it to the end of the warranty, thankfully in my case there was no damage to the main boards (motherboards) although one did damage a KB.
            • прямо
              Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
              by прямо
              Just received it today from a friend.
              Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
              The same rail also does this when the PSU is in standby mode.
              https://ibb.co/5TBkg66
              The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
              What could have caused that?
              First time I have seen such behavior.
              3.3V and 5V rails don't have the same...
              02-19-2024, 09:52 PM
            • h0m3w0rk
              Random Shutdowns/Startup Failure with Corsair SFX 450
              by h0m3w0rk
              I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
              For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
              02-09-2025, 03:19 AM
            • coinwizx
              Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
              by coinwizx
              The power supply is 2020 Corsair HX1200 modular power supply.
              Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
              Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
              09-15-2025, 12:46 PM
            • zunasthegreat
              Dead corsair VS450 with blown TNY chip (cwt)
              by zunasthegreat
              I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
              The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
              08-30-2025, 03:11 AM
              Corsair CX750M [Model 75-002019] - burned output toroid inductor
              by momaka
              Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
              So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
              09-19-2021, 08:44 PM
