need some help with resistor values
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    have a battery charger here that blew itself up like they do .only trouble is i cant find a schematic for it .its a 18v workzone one .so far there are 2 obvious blown resistors and maybe another one , plus the fet is totally shorted which i could do with a cheaper sub for as expensive to buy .
    here are some pics .will post more in next post .
    ah yes unknown resistors are R9 R5 R11.
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: need some help with resistor values
    more pics .oh the fet is 4n80
    • petehall347
      • Jan 2015
      • 4448
      • United Kingdom
      just had a thought .wondered if i might pick up a plug in charger and simply connect the wires to charger socket to save money ?
      if so any special charger needed ? i am guessing not .only 2 connections to battery +-
      maybe this then i could put dc socket into the case of charger box . https://www.ebay.co.uk/itm/18V-1-5A-...kAAOSwZvRaYY-o
      • R_J
        • 9622
        If R5 (gate resistor) is blown, it is likely that ic1 is also defective. R9 is likely a low value 1Ω or less, R5 could be around10~30Ω R11 seems to be 100 which would be 10Ω
        • petehall347
          • Jan 2015
          • 4448
          • United Kingdom
          yes i wondered about the ic cant see what it is though yet .
          edit ...
          looks like 6B55322 . the 3 might be a 1 .
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            clear ish pic of ic
            • R_J
              • 9622
              The ic seems to be a Cr6855 60w current mode PWM control chip
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                what frequency should it be at to gate ? am thinking i could remove the shorted fet to test the frequency and voltage ?
                edit think i found correct value at 65khz .
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  wondering if this is correct mosfet ? https://uk.rs-online.com/web/p/mosfets/7925754/
                  • petehall347
                    • Jan 2015
                    • 4448
                    • United Kingdom
                    r11 is actually 10k and still good .its R4 i cant figure out .i see it starts with a 4 .
                    reads about 280k in circuit
                    edit .removed from circuit it measures 1.3 meg . which doesn't seem right as first digit is a 4
                    • petehall347
                      • Jan 2015
                      • 4448
                      • United Kingdom
                      i looked at the frequency and everything seems to be at 50hz which is of course the mains supply frequency.
                        • 31278
                        that's strange, it has a rectifier so even if the cap is fucked it should be 100Hz
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          might be my meter playing up .only way i can get any sense of frequency measurements is to use just one meter probe am sure it used to work fine if say i put red into live and black to neutral on the mains . i even did something silly and happened to have black probe in my hand and touched red to gate out on the ic . it sure felt like 50hz through my hand .
                          will have another play with it shortly .
                            • 31278
                            probably read 50Hz in the air, radiating from all the wiring in the building.
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              ok new findings and things blowing up .
                              i replaced R9 with a 1k resistor just to have something to make up the circuit . checked frequency at gate out and now zero hz according to my meter had one probe on main cap minus and other on gate out pin of the ic . then a few seconds later 2 rectifier diodes blew up .didnt half make me bloody jump . bearing in mind the mosfet is removed . i have no idea if its because of that or not
                              edit
                              ok tacked in a couple of 1n4004 i think or might be 1n4148 plus botched 5 amp fuse wire accross the blown fuse .anyway that doesnt matter right now .back to 300v dc and zero hz .
                              parts count is adding up now . as need 4 diodes and a fuse including . am guessing rectifier was on its way out anyway .
                              • petehall347
                                • Jan 2015
                                • 4448
                                • United Kingdom
                                diodes marked M7 so am i right thinking they are 1N4007 ?
                                • R_J
                                  • 9622
                                  R9 will be the source resistor for the fet, The ic monitors that line to control the current, If you used a 1K, and the fet turned on, the voltage developed across the resistor will blow CS input of the ic, Max input on that pin is usually 5~7 volts
                                  R9 is usually less than 1 ohm, Also if the fet shorted drain to gate, and blew R5, I can not see how the ic would handle 300vdc going to it.
                                  • petehall347
                                    • Jan 2015
                                    • 4448
                                    • United Kingdom
                                    the fet is out of circuit .was hoping to see if the ic was working or not . can this be done without the fet in circuit ?
                                    • R_J
                                      • 9622
                                      Without the fet, the ic will not see any voltage on the CS pin, it might try and output a few cycles, then shut down, it depends on how the ic operates.
                                      A similar ic would be the ON-Semi NCP1251, its pdf explains how it operates and it may be similar to the Chip-Rail ic works
                                      • petehall347
                                        • Jan 2015
                                        • 4448
                                        • United Kingdom
                                        so are you saying a NCP1251 will be a direct replacement ?
                                        • Petr0x
                                          Bosch 12V and 18V chargers modification
                                          by Petr0x
                                          Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                          You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                          Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                          05-24-2024, 01:00 PM
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                        • Maggiore
                                          GIGABYTE AORUS 15 X5LF mb GA-X5L Values ​​of knocked down resistors.
                                          by Maggiore
                                          mb GA-X5L
                                          Good day to all, I need help with the values of the knocked down resistors.
                                          04-02-2025, 06:15 AM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • corrize
                                          Replacing resistor fuse in Sony DV charger
                                          by corrize
                                          Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                          So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                          It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                          06-30-2025, 06:59 PM
