How open case? CyberPower CP1350PFCLCD
  • Maxbumpo
    • Sep 2019
    • 12
    Greetings,
    I'm looking for tips or tricks to open up the case of this UPS. It's a CyberPower CP1350PFCLCD. I've got the front and back and top covers off, batteries out, and the seam along the top of the case has all the catches released.
    On the bottom seam, only one catch is visible, it looks like there are at least two more that are hidden. I'd like to open this case up to check for bad caps on the circuit board (fault code F03 - charging circuit not working).
    The real trick is that I want to be able to close the case again, without using non-factory parts like screws and a patch.
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Re: How open case? CyberPower CP1350PFCLCD
    Did you check under labels and such? Bastards love to hide screws that way. Feel your way through the stickers with a finger. If not, force is gonna be your friend here most likely.
    • Maxbumpo
      • Sep 2019
      • 12
      Good idea, only one sticker. No screw.
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Let 'er rip then!
        • Maxbumpo
          • Sep 2019
          • 12
          I'm going to keep researching, try to find a non-destructive way to open up the case. I may try a putty knife to pry at the places at the seam where I think the catches are hidden.
          I am really hoping that someone has BTDT and can tell me how to proceed.
          • Maxbumpo
            • Sep 2019
            • 12
            Success! Carefully examining the bottom seam, I noticed three areas where the color of the black plastic changed ever so slightly. They had a length about the same as the one visible catch, so I tried with a putty knife to put pressure on them so they would open in the same manner as the visible catch. Once I had two out of three release, the case wanted to open up like a clamshell and then the third came free.
            • Maxbumpo
              • Sep 2019
              • 12
              Here are some pictures.
              One is the entire half of the case with the board and transformer, rear cover.
              Next are a couple closer pix of the hidden latches, showing the male and female parts.
              • surgeonxero
                • Feb 2022
                After prying open my own CP1500PFCLCD (and breaking all my tabs), I've figured out how you're supposed to open up this UPS.
                1. Remove battery. (Watch a battery replacement video for visual guidance.)
                1a. Unscrew 2 screws at bottom of case
                1b. Slide front panel and disconnect batteries
                2. Loosen rear panel
                2a. Unscrew 6 screws from rear panel
                2b. Lightly pull rear panel to loosen. You will not be able to fully remove the panel because wires do not have much slack.
                3. Remove top plate
                3a. Slide top plate towards rear
                3b. Lift top plate up and remove
                4. Unlock clamshell
                4a. Look at the top of the unit. You should now see two tabs near the center. Push tabs in and separate left and right halves of the case. There might also be a tab at the front of the unit.
                • bossapplesauce
                  • 7
                  Thank you and Maxbumpo for this info. Helped me taking apart mine and appreciate you taking the time & trouble to post it.
                    • Jul 2011
                    • 6039
                    What is the issue with this battery backup
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                      ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 10:50 PM
                      ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 11:05 AM
                      ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
