Generic power supply, how leathal is it?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Generic power supply, how leathal is it?
    Especially since that "850W" psu with that case is based off a solytech platform that blows up at 350W load.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      "BOOM!" says the fraudulent power supply.
      the case is probably flimsy as well. flimsy cases=stripped thread,s bent side panes that won't go on without a fight, and a mb tray that could fex and short the board. buy quality right off the bat and be done with it.
      sigpic
      (Insert witty quote here)
      • Newbie2
        • Sep 2005
        • 885
        The Cooler Master Elite 330 case in the eBay UK auction shown on this thread has decent build quality. It's better than the typical shiny thin sheet metal Powmax or generic cases.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          I would find something like a cheaper antec case bundled with a psu. They usually come with the basiqs, which are low end fsp. Not that good, but they will run their ratings and do it somewhat cleanly.
          Its rumored that the basiq 550W is a delta now, too.
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • Snownomow
            Shock when touching power supply case (ACBel API1PC36 from PowerMac G4 MDD)
            by Snownomow
            Hello!
            I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
            I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into...
            07-30-2020, 02:20 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
            ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
            This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 10:50 PM
