IDX camera power supply turns off after a while
  • zx81
    • Mar 2014
    • 118
    IDX camera power supply turns off after a while when warmed up. But will turn on again quite quickly when power is cycled.
    Any help on what to do to diagnose this fault would be very much appreciated.
  • redwire
    • 3912
    Re: IDX camera power supply turns off after a while
    A lot of the board's soldering (to through-hole parts) looks like fractured joints.
    The DC output connect has a cracked GND pin, and another is burning the plastic - resolder all those 4 pins and check the connector.
    Pins by R54, bridge rectifier etc. all look in need of resoldering.
    • R_J
      • 9606
      Your problem is with a burnt contact in the plug, Red wire. Fix that and I bet it works fine.
      I would just remove the wire from the plug and solder it direct to the +V hole next to the plug
      That connection is getting hot and blackened the plug. It will also be corroded so would be cutting out
      • zx81
        • Mar 2014
        • 118
        redwire and R_J thank you for taking the time to look at the pics and your replies. I will take a look at everything you guys have suggested and will update when done.
        Thank you guys.
        • R_J
          • 9606
          This would be one way to fix the bad red wire connection, you could remove the plug completely and solder the two black grounds and the red positive directly to the board
          Once the plug gets hot like that, it takes the spring tension out of the metal contact and the connection gets worse.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            If possible, replace both the harness connector (including contacts), and the PWA's connector, Chances are that the contacts on both connectors have been damaged. Or hard-wire the harness.
            One of two things probably happened. 1. The crimp in the harness red wire contact was poor and gradually broke down due to increasing heat. 2. The service loop of the harness in so tight that it mechanically stressed the contact between the socket and pin, resulting in a gradual break down due to heat.
            The latter, mechanical stress, can also deform low current signal contacts and result in intermittent contact (e.g. the PSON* or PG wires in a 20- or 24-pin ATX connector).
            PeteS in CA
            • zx81
              • Mar 2014
              • 118
              Update.
              I have removed the connector and soldered directly to the board. Will monitor the power supply over the next few days and report back.
              Thanks to all of you for your fantastic advice and guidance.
              zx81
              • zx81
                • Mar 2014
                • 118
                I have tested the power supply for a couple of days now and am happy to report that it is running perfectly
                Thanks once again to all of you for your comments and suggestions.
                zx81.
                • frica
                  • Nov 2017
                  • 37
                  • Spain
                  +1
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    DVR camera recorder switching power supply capacitor failure really
                    by sam_sam_sam
                    These cheap non brand capacitors at it again
                    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                    Well at least I have the cameras back on line I to try the...
                    01-22-2022, 06:28 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
