Corsair HX650W
  • storexxm
    • Oct 2012
    • 107
    • Vienna
    Corsair HX650W
    Hello.
    I hope maybe someone can help me.
    My PSU seems to be faulty but I don't know how to repair.
    I only connect it to my motherboard. When I leave the RAM out all the LEDs become green and everything stays on power. When I put a ram in the computer it comes into an on/off loop. sometimes it stays on for up to 15 seconds but I am sure the LEDs are flickering a bit. So I guess the voltage is not stable. Sounds like a broken capacitor, or can this be some kind of power management what is broken?
    Would be cool if someone know that issue and can help me with this
    (I already opened the PSU but unfortently I can't see a broken cap)
    Thanks to everybody-
    • Jul 2011
    • 6040
    Re: Corsair HX650W
    Post a picture of both sides of the mother board in question
    Post a picture of both sides of the switching power supply in question
      • 31051
      Re: Corsair HX650W
      how many sticks of ram have you got and did you try them one at a time?
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        Re: Corsair HX650W
        this type of symptom of an on-off boot loop is typically caused by a bad mobo or bad ram. either the ram modules are bad or the dimm slots on the board are bad. could also be a bad imc in the cpu but not likely. this is not a psu problem because the psu stays on without ram.
        • storexxm
          • Oct 2012
          • 107
          • Vienna
          Re: Corsair HX650W
          Sorry for my late answer & thanks for every reply-
          The motherboard is definitely okay, because its works like a charm with another PSU. So it has to be the PSU itself. I can open it again, but I couldn't find any optical problem. Does somebody ever had the same problem?
          • storexxm
            • Oct 2012
            • 107
            • Vienna
            Re: Corsair HX650W
            Any ideas?
              • 31051
              Re: Corsair HX650W
              well that coil with the burn mark needs investigating.
              did you buy this new?
              i'm not sure it's just coincidence that the heatsink above the burn has sleeving on it!!
              • storexxm
                • Oct 2012
                • 107
                • Vienna
                Re: Corsair HX650W
                no, its a used one...
                got it from a friend
                  • 31051
                  Re: Corsair HX650W
                  better ask the friend if it was opened or anything.
                  • Pipolups
                    Corsair K70 LUX RGB dying LEDs
                    by Pipolups
                    Hi there !
                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                    10-08-2024, 11:58 AM
                  • Takeatry
                    Yet another Samsung QLED Boot Loop
                    by Takeatry
                    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                    10-04-2024, 02:57 PM
                  • kitor
                    HP 400 G6 DeskMini broken bios - never ending boot loop - fix request.
                    by kitor
                    I have HP 400 G6 DM which is not booting - it will spin up for like 30 seconds, then turn off for a few, boot again... and it goes on forever.
                    Can anyone check this dump and maybe attempt to repair it?
                    SN is 8CC1340PC8. Board is "Missandei-AUD Rev B Model F91" DAF91MB16B0...
                    07-09-2024, 12:19 PM
                  • chth96
                    Is it possible bridging tiny broken trace
                    by chth96
                    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                    cutting tiny trace.
                    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                    12-03-2022, 11:32 PM
                  • blaster_
                    Samsung UE49MU6105K - boot loop, horizontal lines
                    by blaster_
                    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                    06-22-2022, 05:19 PM
