Vision Fitness T9700 treadmill motor controler/power suuply dead
    Re: Vision Fitness T9700 treadmill motor controler/power suuply dead
    May be it has interlock switch that cut off the power when the covers are not in place.
    We probably need to see how the whole thing wired up.
    Check to see if have very low resistance reading between Line connector and the AC plug's Line, same for Neutral connector and the AC plug's Neutral.
      Hi budm
      There are no switches like that at all on this treadmill
        If not then you have to check the resistance reading between board L/N and ac plug L/N.
          Cant check ...not at location
            Good news...maybe
            I reconnected all the cables and used my direct ac connection and the treadmill seems to power on and all motors and display work.....
            No further testing done but thats a good sign
            The only wires i did not connect were the orig ac line and ground so maybe wiring issue or issue with the circuit breaker
              Originally posted by shelby5041 View Post
              Hi
              Yes i have 115v at terminals next to transformer
              I thought you checked this and there WAS 115v ???
                Something is not adding up, must be error some where or wrong data.
                  yes i did have 115v coming out of circuit breaker and i had 115v at the hot wire going to the line connection....
                  and the lighted up power switch tells me the circuit breaker is ok
                  when i disconnect circuit breaker wires the power switch will not light up so that proves the circuit breaker is working?
                  anyways something is odd for sure and maybe something very simple
                  i havent done any further testingt but it does power on with my direct ac connection...maybe something funky going on with the circuit breaker??
                    Easy enough to check the connection from the AC plug all the way to the board Hot and Neutral.
                      well today i did some more testing of the treadmill and it seems to be working ok..it goes through and elaborate auto calibration process....treadmill goes up down and various rpms and then says ready
                      and i tried it and it seems to be working fine...i guess if i have to i will just leave the direct wire plug on it and just not hook up the circuit breaker and orig plug and switch...im not worried about that...as long as machine works im happy..i got it for free and its a $3000 retail gym quality treadmill very nice and quiet and sturdy
                      thanks for everyones help....still dont kno what the orig issue was but its not so important right now..if i ever get time maybe i will look more into it but its not high priority right now..
                        hi
                        issue was bad rocker switch neutral connection
                        treadmill works great now..i just bypassed the rocker switch..will order a new one when i get time
                        i figured it was something simple...i guess next time a fitness center throws out avery expensive piece of equipment they should have it looked at...their ignorance is my gain
                          How amp go through this switch hot leg and neutral leg because I have seen mig welder do this kind-a crap you might want to put in a 120 volt relay good for 10 amps for each pole and use a 4 poles use two poles for hot leg and two for neutral leg then went it does not want to power ON it will be the relay
                          This is just a thought
                            Its wired through a circuit breaker prior to connecting to power board so it should be ok
                              The problem with going through a switch like that is the contact are not heavy enough for the type of current that the motor can pull at start up
                              That is why I made the comments earlier
                                Sam
                                you are correct....thats why the hot and neutral section of the switch are both burnt dark colored and the neutral just basically melted ...very thin guage contacts....
                                Right now i removed the switch so when you plug it in the unit powers on
                                maybe ill just leave it that way or find a heavier duty switch here is link to the switch that came ith machine https://www.ebay.com/itm/5x-Red-Lamp...MAAOSwtjhb~AoO
                                And bud m.you were right ...something didnt add up or error in user me lol......i never checked resistance from board line/ neutral to plug/switch.....if i would have i probably would have found the open neutral connection sooner....i never would have thought the rocker switch was bad since it lit up when powered on and i had 115v on the board when using my non contact voltage tester....which was another false indication since the 115v was present but the circuit was not....that portion of the switch was good but the outgoing circuit was bad so it was a false indication
                                Fyi i am not an electronics guy just a guy who likes to tinker with things i have no background at all in electronics and i appreciate all the advice in here...next time i need to be more thorough on followingbthrough with suggestions by experts like bud m and rj and others
                                  "i never would have thought the rocker switch was bad since it lit up when powered on and i had 115v on the board when using my non contact voltage tester."
                                  If we had known that you were using that non-contact tester, we would have told you not to use that for checking for the actual Voltage, it should be done with the meter, and I see why you tester lights up when Neutral is not connected due to bad switch.
                                    Sam
                                    This might not be any better than what was in there if you want to go cheap and easily replaceable you could use a regular light switch that used in your house just use two of them in electrical box that has two switch place in the box
                                      you are correct bud m
                                      However i was assuming it was a board issue the whole time so my ind was directed in a diff area...i even removed the caps and tested using my esr meter and they all were good....lesson learned...check the easy stuff first using the proper equip and methods....i really thought the board,was bad since its a common issue on this model treadmill....
                                      And sam im not looking to make this a project..too many other things to do...this was just a good trash find....just looking to get item to work which it is.....im going to leave as is or order the same switch that came with the treadmill....and will contact vision fitness and lodge a complaint ...
