FSP 19V 180W power supply repair
  • lucky13
    • Aug 2007
    • 412
    #41
    Re: FSP 19V 180W power supply repair
    Toasty,
    Sorry I did not mean to ignore your question.
    It was for a Viewsonic 27" N2700W.
    I've already got the s/m of the TV but it does not show anyting useful about the external power adaptor. It does not even show the main board power input area so I can see if I can modify it touse 24v supply (which I have).
    Strangely the back of the TV says Input: 19Vdc 4A.
    So, maybe one of those el-cheapo ac adptor from eBay will work.
    Yes, I have freeze spary but the voltage fluctuates as soon as I connect just the ac side so I never sprayed anything. Also, when it stopped working after a minute, the aluminium heatsink is barely warm to the touch.
    Mmm, time to check if Digikey has this chip....
    • Toasty
      • Jul 2007
      • 4171
      #42
      Thanks for the info. I don't mean to be grumpy, it comes naturally. With all the info in front of us, it's easier to help.
      I'd like you to try chilling the IC's one at a time. If you get a change, it's likely the faulty one. You have 3 on the back of the board. The L5991 appears to have 3 SMD transistors right next to it, hit them too.
      I'd like you to take it slow and not blast the whole board. One at a time plz. Also, be careful of causing condensation when you do this.
      (FYI- They are ~$40 on eBay)
      Toast
      veritas odium parit
      • lucky13
        • Aug 2007
        • 412
        #43
        Darn, all the cans are empty... need to pick some up next week.
        Yes, I seen those on ebay. They are not the exact original as this one has a small fan to blow in cool air. Those on eBay don't.
        • lucky13
          • Aug 2007
          • 412
          #44
          Correction to what I said earlier. I have NOT freeze spray anything on this board.
          I am looking at the data sheet for L6561 and see that pin8 Vcc has a 20v zener diode built in.
          I checked the voltage (pin8 to pin6), it is jumping between 7 and 9v. That is too low! There is no way the zener can clamp the internal to 20v when the input is so far below.
          So, perhaps the problem is near the input?
          • Toasty
            • Jul 2007
            • 4171
            #45
            >>Correction to what I said earlier. I have NOT freeze spray anything on this board.<<
            ??? When did you say that...?
            Zener is for protection/limit, not regulation. Internally regulated 7v.
            L5991A: http://search.digikey.com/scripts/Dk...=497-3996-1-ND
            L6561: http://search.digikey.com/scripts/Dk...=497-4582-1-ND
            Did you get the voltages on the other pins I asked in #34?
            There are 3 IC's. We know 2, what is the third?
            Toast
            veritas odium parit
            • lucky13
              • Aug 2007
              • 412
              #46
              Toast
              Post#42, 2nd last paragraph....
              I will answer the other questions next week as I left that thing at work.
              • lucky13
                • Aug 2007
                • 412
                #47
                Min order 2500 pcs for that L6561.
                And I don't understand how 1 pc of the L5991 comes out at Cdn $11.18 ?
                • Toasty
                  • Jul 2007
                  • 4171
                  #48
                  ?? 1 = $1.44 US // $3.18 CAN
                  Top of page... You're looking at alternate packaging, a reel of them.
                  >>And I don't understand how 1 pc of the L5991 comes out at Cdn $11.18 ?<<
                  L5991 is $2.70 US // $1.69 CAN
                  Post 42 is mine. Just drop it. You never said you freeze sprayed anything. That's why I was curious as to why you said you didn't freeze anything when in fact you never said you froze anything.
                  Are we confused yet? I am! wheeeeeee!!!
                  Have a good weekend.
                  Toast
                  veritas odium parit
                  • lucky13
                    • Aug 2007
                    • 412
                    #49
                    Sorry was POST #41 (I couldn't count)
                    Toasty,
                    The third IC looks to be M101AC. Now, it could be 107AC. The picture I took previously cannot definitively show a 1 or 7. I will get a better magnifier glass on Monday to look again.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #50
                      101AC. Nothing found under 107AC
                      http://search.digikey.com/scripts/Dk...=497-5442-5-ND
                      http://www.mouser.com/ProductDetail/...bJYleECsqInS5i
                      Digikey says "non-stocked" (2,000 min qty) but has 102 on hand. LOL
                      Mouser is 1 at a time.
                      If you call or write them, you might just get a few tossed in with your other chips. I think you can get freebies from ST directly also. Enough BS and you'll get piles of stuff. Just don't tell them your fixing something...
                      Toast
                      veritas odium parit
                      • Gianni
                        • Jul 2008
                        • 681
                        • Italy
                        #51
                        I think they are jumping between Vcc on and Vcc off because is missing the voltage coming from auxiliary winding.
                        Can you feed with an external PS the L5991A?
                        If the PSU remains ON with an external feeding you know the controller is ok and you should check why there is no internal feeding.
                        Another reason could be a bad electrolytic on Vcc pin/ auxiliary winding but you have already replaced them so I have no more suggestion.
                        If you can keep on the L5991A (Vout must be 19.5V) check if the PFC works, you have to find around 350 - 400Vcc on the big black cap, if the voltage is only Vac x 1.41 then the PFC doesn't work.
                        It will be useful if you can draw the schematic following the tracks on PCB.
                        Ciao
                        Gianni
                        "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                        H. J. Brown
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • shamsudeen
                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                          by shamsudeen
                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                          07-19-2025, 07:14 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
