Flakey Bestec ATX-250 12Z?
  • everell
    • Jan 2009
    • 1514
    Re: Flakey Bestec ATX-250 12Z?
    Hi ratdude - sorry to be so hard on you in that last post. I hope you will agree that there are some people who need to read and heed such advice. I didn't realize you are a robotics guru, so an apology is in order. I will remind you that safety glasses are important. You are probably taught that in school. Eyesight is something you just can't replace. So at home - safety first. OK?
    When I started looking at computer power supplies - I had no idea that the first one I looked at would cause such an uproar. In retrospect, I would not recommend any newcomers to tackle the Bestec ATX-250 12E. It is not for novices. I didn't see that much of a problem with the '12Z. But there are many people who condemn it simply because it is Bestec. Glad you got yours up and running. I doubt it will give much trouble other than possibly needing some crap caps replaced. Keep us posted on how well (or bad) it does.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      oh crap:
      I got an I/O error when installing. i think its the cd. like i said, the hd sounds better than the dead clone (sounded like one from 92, with all the whine). the cd might have been scratched/defective. off to burn another, will test again soon.
      i NEVER run power supplies with the lid off. i ALWAYS make sure the caps are run down (jumpered on with fan attached, with no power cord, run until fan stops) before i open them.
      sigpic
      (Insert witty quote here)
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • madan1
        555 based power supply getting too hot
        by madan1
        Good day.
        I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
        The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
        After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
        When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
        06-23-2025, 04:38 PM
