fore es-2810 PSU
  • yonu
    • Nov 2007
    • 138
    fore es-2810 PSU
    anyone happen to have any idea if a standard at PSU can be used in a fore Ethernet switch my psu bit the dust at least i hope it is the psu and I need to test it
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: fore es-2810 PSU
    if they use 12v, 5v, or 3.3v, then a computer psu will work just fine. You would just have to wire it all up and wire a switch to the power_on to a negative on the main 20/24pin connector for a switch.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You might have issues with not enough load to keep PSU on.
      Mann-Made Global Warming.
      - Dr Seuss
      • yonu
        • Nov 2007
        • 138
        not atx i actually mean AT as they are at connectors on the switch
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Hmmm, you would have to check the pinout.
          I have a old upgrading and repairing pc's 5th edition around here with the pinout for a at power supply's connectors.
          Also, those older power supplies would usually fry themselves without a minimum load on each voltage.
          • yonu
            • Nov 2007
            • 138
            ok guess i will start looking for a nerw switch
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              AT has:
              +12v = Yellow Wire
              +5v = Red Wires
              -5v = White Wire
              -12v = Blue Wire
              -- some also have [rare]
              +3.3v = Green Wire
              Do not use Orange wire for power. That one just tells a mobo that PSU is ready.
              Most AT PSUs probably don't care about minimum loads like ATX units do.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Those with +3.3v will have three 6 pin main power connectors vice just the usual two.
                - Dr Seuss
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  Originally posted by PCBONEZ
                  AT has:
                  +12v = Yellow Wire
                  +5v = Red Wires
                  -5v = White Wire
                  -12v = Blue Wire
                  +3.3v = Green Wire
                  I think they care more about minimum loads. According to upgrading and repairing pc's 5th edition, almost all do need a minimum load, and only higher end astecs and pc power and coolings had a minimum load built into them for bench testing.
                  • yonu
                    • Nov 2007
                    • 138
                    thanks guess i will hope for the best and try it weith an old at supply at least then i will know if it is the switch or the psu
                    • yonu
                      • Nov 2007
                      • 138
                      well I finally got around to sesting the switch it is something in the switch i hooked up a normal at power supply if i hook up only half of the connector the fans turn on if i hook up the whole thing nothing comes on so i suppose the switch just crapped out
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        As I recall most AT PSU's will kick on with nothing connected at all.
                        - Dr Seuss
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3113
                          All I know is that IBM would put little resistors in place of hard drives in thier early systems to put a minimum load on the psu. I've had countless deers and other gutless wonders as well as new antecs and a supermicro that have no problem running with nothing attached.
                          I fried a old lite-on AT psu because it had no minimum load and when I jumpered it it just ran for a second then *pop*.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Probably had a load resistor but not big enough.
                            - Dr Seuss
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • Natob82
                              Micro Momentary Push Switch?
                              by Natob82
                              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                              12-21-2022, 05:22 AM
                            • grimacelord
                              NEC TurboExpress On/Off Power Switch Replacement Help
                              by grimacelord
                              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                              11-09-2023, 09:49 AM
                              Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                              Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                              ( needs more cam circuits for the machine to work correctly again )
                              https://www.ebay.com/itm/275321870186
                              To
                              3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                              ( not 4 positions but the right amount of cams circuits )
                              https://www.ebay.com/itm/274660439950
                              I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                              03-18-2023, 05:12 PM
                            • Powderfanupnorf
                              Dell AL440LX power on switch circuit help required
                              by Powderfanupnorf
                              Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                              So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                              My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                              06-24-2024, 01:24 PM
