Can someone please explain to me what this chip is CM03X
    • Jul 2011
    • 6024
    Can someone please explain just what this chip is suppose to do and how it works
    The data sheet is very vague about what this chip is
    CM03X
    https://cdn.badcaps-static.com/pdfs/...c907c22d05.pdf
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8670
    Re: Can someone please explain to me what this chip is CM03X
    Looks like just a MOSFET switch meant to be run in saturation, of sorts...where is it being used?
      • Jul 2011
      • 6024
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3560
        • slovakia
        the datasheet say
        The CM03X is designed to reduce the no load consumption or
        so called Phantom power for AC Adapter, Desk Top PC power
        supply, LCD Power Supply and others.
        but they can add typical installation
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • Troystain
          Help EZP2023+ updated chip database for w25q256jveq?
          by Troystain
          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
          I need to add w25q256jveq chip but I do not know what data should I type.
          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
          11-25-2024, 12:53 AM
        • inck243
          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
          by inck243
          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
          The BIOS...
          07-25-2024, 09:17 AM
