legrand daker 6kVA error code 30
  • mokfad
    • Dec 2018
    • singapore
    Does anyone here can help to explain what is error code 30 indicated on the Legrand Daker 6kVA UPS display panel ?
    I have checked the manual but there is no mentioned on this error code.
    Appreciate all the help on this.
    Thank you
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Re: legrand daker 6kVA error code 30
    Hello, Mokfad.
    But what's wrong with you? Did you stop doing something special?
    I just downloaded the manual, I see that you can connect via USB or RS232. Try downloading the computer software. There you are likely to be able to see the equipment's error records in more detail.
    On the manufacturer's page you have these available:
    "UPS SETTING TOOLS" and
    "UPS COMMUNICATOR"
    "UPS MANAGEMENT SOFTWARE"
    You're right, that error 30 does not appear in the user's manual.
    Can you upload a photo of the control panel with the error?
    regards
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Grouickman
      Hofmann geodyna 6300 Wheel balancer
      by Grouickman
      Hi there,
      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
      03-31-2025, 05:29 AM
    • bohaboha
      error code 0x80072f8f 20000 When widows upgrade to 10
      by bohaboha
      when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
      in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
      Error Code 0x80072f8f 20000
      08-30-2023, 07:06 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • GoodCapDude
      Sony XBR-75X940E intermittent 6 blinks error code
      by GoodCapDude
      Hi everyone. First post on Badcaps!
      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
      09-20-2025, 06:07 AM
