legrand daker 6kVA error code 30
  • mokfad
    • Dec 2018
    • singapore
    Does anyone here can help to explain what is error code 30 indicated on the Legrand Daker 6kVA UPS display panel ?
    I have checked the manual but there is no mentioned on this error code.
    Appreciate all the help on this.
    Thank you
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Re: legrand daker 6kVA error code 30
    Hello, Mokfad.
    But what's wrong with you? Did you stop doing something special?
    I just downloaded the manual, I see that you can connect via USB or RS232. Try downloading the computer software. There you are likely to be able to see the equipment's error records in more detail.
    On the manufacturer's page you have these available:
    "UPS SETTING TOOLS" and
    "UPS COMMUNICATOR"
    "UPS MANAGEMENT SOFTWARE"
    You're right, that error 30 does not appear in the user's manual.
    Can you upload a photo of the control panel with the error?
    regards
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
    • bohaboha
      error code 0x80072f8f 20000 When widows upgrade to 10
      by bohaboha
      when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
      in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
      Error Code 0x80072f8f 20000
      08-30-2023, 07:06 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      The TV does not turn on, the standby indicator is on. All voltages are present.
      Emms is dead. Not readable, not detected.
      Replaced emmc.
      But with another dump there is no launch
      Terminal log
      UART
      AC_ON
      RPMB key is not yet programmed
      HASH1_VERSION=0x00000000 64bit
      E-B
      FDE enabled
      layout pattern onebin by SAR7,0...
      06-01-2025, 02:11 AM
    • CdDvdFlash
      Hitachi HTA-DD3W AV Receiver Error Code -Protect-
      by CdDvdFlash
      I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
      07-10-2023, 06:05 AM
