FSP300-60PN, failed to start
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: FSP300-60PN, failed to start
    Didn't some of the old antec-cwt units use that "flying resistor" method?
    Good job on the recap, and getting rid of the needless resistors.
    • yanz
      • Nov 2004
      • 910
      burn-in test :
      pls ignore how messy the bckground is.. :-D
      and then, with the real load (p3 933MHZ system doing folding@home) :
      all the rails were good, me think.
      • yanz
        • Nov 2004
        • 910
        Summary(?)
        The flaws (in my opinion) of this fsp300-60pn PSU :
        1. 120mm fan (yate loon fan) is still good, but making a rattling sound. it give too low air pressure for the components inside secondary area. (how about using a bit more reliable fan like, err.. panaflo or nidec?)
        2. the deadzone design doesnt help much with cooling in this PSU.
        3. dummy resistors are touching the caps, the coil, and all the small components nearside. and why those engineers have too put a stupid 2,6W big resistor on teh 5V rails? maybe for an immediate load? (or maybe they're just paranoid..?)
        My solution :
        1. I againts an idea of using a 120mm fan on this PSU, so i use a 90mm panaflo fan (moderate cfm). it will give enough air pressure to secondary area, and it will not block the whole input hole, making the circulation better, and minimize the dead zone effect.
          Or, i could make a hole on the PSu casing near the secondary side, and use my sunon 120mm fans. But i didn't do this.
        2. Remove all the dummy resistor. They are dummy and killing the components. No ill effect to PSU operation after used in pc system, but dont take all my words though, it's just what i observe and my experience. i could be wrong.
        • yanz
          • Nov 2004
          • 910
          The PSU is happily powering a E5200 C2D system with Nvidia 9300 now. Will monitoring the KZJ cap periodically (each 6 month). I have the feeling that KZJ have different characteristic then KZG.
          Oh, if you have any comments, pleast post ones. And, thanks for ur times here..
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Look for a fan in the neighborhood of a nidec ta350dc. They are 92mm x 25mm, and can push up to 60-70cfm not very loudly.
            http://cgi.ebay.com/DELL-Case-Fan-P-N-P2780-Nidec-Beta-V-TA350DC-M35291-35_W0QQitemZ230342457512QQcmdZViewItemQQptZCOMP_EN_Networking_Components?hash=item35a17af8a8&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|293%3A1|294%3A50
            he he, a 150cfm one.
            • yanz
              • Nov 2004
              • 910
              #26
              err.. one more conclusion : there are risks in buying second hand psu(s). this is just one example. if u know how to fix it and love the fum of solder, go try it. and a working one doesn't always mean a healthy one. always open it to check the innard (and maybe it will give u a 'nice' surprise).
              just my 2 cent
              • yanz
                • Nov 2004
                • 910
                #27
                woops, we posted almos at the same time thx!
                yeah.. i think i have one nidec 120mm fan although not exactly like your recommendation. a louder one would sitll be okay because this psu use a "noise killer" that operating that fan at stupidly low voltage..
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  thats a 2.3A fan though, may burn it up.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    http://www.newegg.com/Product/Produc...82E16835213002
                    That might be powerful enough
                    • yanz
                      • Nov 2004
                      • 910
                      #30
                      if u give me one, coz it's a $36 fan.. hehe
                      • yanz
                        • Nov 2004
                        • 910
                        #31
                        eh? i know those fan. it seems they are $2-3 cheaper here, dunno why.
                        yep. i have used that ta350dc once for other project.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Nidecs are the only fans I use now.
                          • yanz
                            • Nov 2004
                            • 910
                            #33
                            Antec have a smarter designer then. Or unlikely? coz they choose fuhjyuu craps.
                            and the voltage switch-selector too. thx
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Ahh, the old leadman "APFC"
                              • Wizard
                                • Mar 2008
                                • 2296
                                #35
                                These resistors serves to equalize loads presented to PSU point of view because the computer's loads is very dynamic (high impredance in one moment then low impredance in next instant). With this resistors, this helps to stablize the regulation and less jumpy/spiky and keep PSU in sweet zone more consistently.
                                Plus these resistors are sized as such that resistance is higher than the loads, when load becomes higher, resistor's role in total load becomes small.
                                In old days, IBM had load resistors plugged to unused drive connectors on late PC/XT and AT boxens and other high end stuff.
                                Cheers, Wizard
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  why dont you just oil the old fan. take off the sticker, remove the rubber plug, squirt some lube in there, put plug in, and put tape or whatever over the plug to hold it in.
                                  sigpic
                                  (Insert witty quote here)
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    If its a ball bearing fan, its not that simple.
                                    The races for the balls (...ahem) may be worn out and causing the balls (...ahem) to move back and forth and rattle around. Or the testi...I mean balls may be worn out themselves.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #38
                                      Nice recap job! And it's a good thing you removed those hot resistors from there.
                                      Actually, it's not too complicated either. Basically you do what ratdude said, but with one extra step - you remove the locking washer from the fan axle/shaft and take apart the whole fan (you should do that anyways since it's not that much more work). Then you dump plenty of oil on the ball bearing(s) and some on the axle. This should keep the fan quiet for at least a year.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Usually all the oil does is just make it a lot harder for the balls to move around and make noise. It would eventually come back once the oil makes it way through.
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          #40
                                          That's true, but like I said the fan will probably work fine for a year or two, depending on the oil you use (though I guess this wouldn't be a suitable repair for a customer's computer). After that it will need oil again.
                                          The key to a longer lasting fan, though, is to catch it before the bearings go dry. Otherwise they start to wear out very quickly after that point.
                                          • AJ847.63e
                                            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                            by AJ847.63e
                                            Hi Folks,
                                            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                            05-06-2025, 10:37 PM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
