Tyco spi270f4b24 ATX supply repair tips (not starting)
  • kaboom
    replied
    Re: Tyco spi270f4b24 ATX supply repair tips (not starting)
    It's an FSP according to the UL code E190414.
    That riser control board reminds me of units from the 80's that used the same- except they were thru-hole, not SMT...
    The "click" you hear could be either the main supply or PFC booster starting into a short and shutting down. Check the sec rectifiers for shorts, easily by plugging ohmmeter into the output leads. Red wire into each output, black wire to sec common- any black wire on molex/ATX plugs. Be sure the sec caps are discharged first.
    If they check out, PFC could be starting and shutting down. Check boost voltage across the big cap- first in standby, then when connecting PS-ON. If booster is working, you should see the voltage increase. Again, measure across the boost cap for this. You may have to solder leads on and attach to your meter's clips.
    When the booster is running, you'll have ~400V DC on that cap.
    Do the outputs give a "pulse" of voltage when attempting to power up? Try a 12V fan directly connected to the +12 output.
    You can't always use the internal fan to check this, since there may be a controller/resistor- it is an FSP after all...
    It's not fun when dealing with a "gotten to" unit either.
    replied
    look for a shuttle psu - and re-cap it.
  • Dannyx
    replied
    Yeah, looks like sh!t I know....told you it's been sodomized At this point it would probably be easy just to adapt another supply, but still: I like a good challenge. Space is at a premium inside this thing, so obviously any old ATX won't fit.
    replied
    wrf is that?
    i would have thrown it at the owner!!
    raped & butchered!
  • Tyco spi270f4b24 ATX supply repair tips (not starting)
    Good day folks. Another challenge was issued to me today: fixing a dedicated ATX supply for a cash register terminal monitor or some junk, doesn't really matter. It's a Tyco spi270f4b24 and of course there's no info available on it, so I was hoping based on some of the pics and discussions that someone would look at this thing and suggest a similar one they've encountered, or at least point to a similar issue. The pics are not spectacular - bad lighting, constant pet-peeve at this new shop
    The supply is not starting: standby is present at the output, but nothing happens when you short the green wire to GND. Actually there IS something happening: a click is hear, kinda like a relay closing, and then it does it again after it's unplugged. No relay on the board though It's made relatively complicated by those two riser boards, "computers" as I call them. It's worth noting that I took on this project somewhat "second-hand", meaning others have messed around with this supply before me, some of the components have been changed, caps were changed, even the controller chips on the risers were swapped, from what the guy who handed it over to me told me, so it would be great if I were the one who actually did it.
    The closest we got to actually diagnosing the fault was one of the optoisolators: the reason it's sticking up in the air like that (you can just about make it out in one of the pics, soldered to the UNDERside of the board), is because my workmate suggested measuring the resistance across the "transistor" side of it, as he's thinking the primary is not receiving the "ON" signal. There is a resistance drop on those pins when power is applied indeed, but if I install the opto back in its place the way it should be, nothing happens: there's 14v on one side and 1v on the other and my colleague thinks this voltage should make it across to get to the IC on the riser board. Indeed, the trace from the optoisolator does lead to a pin of the riser, but I haven't dissected the supply enough to know what those ICs actually are. My fairly modest knowledge of ATX SMPSs would tell me one is a PFC controller and the other is the "run" controller for the outputs. "V-AUX" is present (those 14v I was mentioning), but it's not jumping across the optoisolator despite this guy replacing several of them...I still think the control IC is not functioning, but that doesn't explain why there's no VCC going through to the IC. I THINK this place has some oscilloscopes I could source to probe those output pins of the ICs after we identify them. Better yet, power the ICs with a bench supply at their rated voltage to see if 1: I get an abnormal current draw which would mean something's shorted and 2 if the IC pulses the gates of the FETs as it should (it's obviously NOT, but this will also help determine whether it's a power issue or an IC issue).
    No shorts or anything obvious unfortunately on the board...any help from people more skilled with ATX supplies would be great...I used to fix these relative ease, but I haven't done it in quite a while (not wanting to bother) and it seems now I need it but I forgot how to do it
    I forgot my past, my humble beginnings when I was just a skinny lad with his multimeter probing away at ATX supplies and fixing them for a quick buck....it's all SMDs now, supplies are getting more and more complex.....*sad*
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
