Looking for a reliable +5V and +12V PSU with low ripple
  • Y. Signal
    • Apr 2018
    • 77
    • Spain
    Hello. I'd like to get suggestions for a reliable PSU with good caps and low ripple with +5V (adjustable), +12V and optionally -5V. I don't really need the -5V but it would be nice to have this output too.
    I've read good things about the Meanwell MWP-606A with 50mV ripple for the +5V output (the most important for my application) so I've called to an official distributor. Sadly this PSU is not produced anymore and the replacement they suggest me (TP-100A) has 100mV ripple noise, more than the 80mV of the RT-125A I'm currently using.
    Apart from this second PSU I plan to buy, I'd like to get cleaner outputs from my actual RT-125A, is using a line filter the way to go? if so, could you recommend me one or point me on what I should look for? my application (arcade boards) typically uses 2 to 5A, and the efficiency of this PSU is 80% if I recall correctly.
    I live in Europe, so being able to buy it from here is a big plus since import taxes are very high.
    Thank you in advance.
    • Jul 2011
    • 6040
    Re: Looking for a reliable +5V and +12V PSU with low ripple
    I hope you find thi usage
      What effect does the 100mV have on the arcade board?
      • Y. Signal
        • Apr 2018
        • 77
        • Spain
        Hi, I want to reduce ripple and noise to prolong the life of the arcade boards since they are very old. With some boards that are not so well built in some analog TVs I have observed some wavy noise across the screen, not sure if that's due to the RT-125A.
        Would a line filter help with this? could you recommend me one, or what features or certifications should I look for?
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
        • Ady2017
          Is there a manufacturers tolerance for ripple?
          by Ady2017
          Hi all
          I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
          As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
          The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
          11-13-2021, 11:46 AM
        • Antonynl
          Lenovo 530 Vcore : what is the maximum ripple?
          by Antonynl
          Hi
          I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
          Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
          What is normally the maximum ripple allowed on say any of the power supplies? A few %??
          The ripple is on both Vcore as outlined in red in attached photos.
          Could be a bad driver?
          Cheers...
          04-29-2023, 04:59 AM
        • sumilumi
          700mv ripple on Akai Sampler linear supply
          by sumilumi
          Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
          I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
          On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
          01-02-2022, 10:12 AM
