modify a dell server psu to work in a shuttle x pc
  • KountZERO
    • Nov 2009
    • 78
    Brief, psu died in shuttle, too far gone to be recoverable.
    Went through my pc scrap and pulled a slim line 280w from a gutted out power edge 750 that works fine.
    It has a 20 pin atx and 6pin power connection. The pinouts are standard for atx except for the fact that there is a +3.3vsb on the 6 way along with the 2 12v suplimentary lines and There is no purple +5vsb on the 20way.
    Compared with standard atx 20 pin and other than the missing +5vsb averything is the same including colour code (i expectected it to be as Dell has been using standard atx since 2000 'ish)
    A quick probe around finds 5.7v always on a jumper pin (the stanby circuit and fan controller are on a daughter board that is joined with a row of jumpers to the main board)
    Would it be safe to assume i should be able to find a suitable +5vsb location or will i have to knock up some kind of ghetto fix to get the clean +5vsb needed.
    B4 you ask, the Shuttle PSUs are way overpriced for what they are and im getting a bit fed up with using a regular size psu and not being able to put the cover on properly. Its my plex/sickbeard/headphones server and i had it running just right so would rather resurect than start afresh
    Tried to find a schematic for it and failed
    Its marked as an HP-U280EF3 v. A00, (annoyingly the H01 version is +5vsb apparently.)
    I believe its a Delta made item?
    https://www.ebay.co.uk/p/Server-Powe...d=372432300746
    Thanks, Sean
  • omega
    Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
    by omega
    Hello all,
    as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
    Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
    02-09-2024, 03:34 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • hazem3636
    need Bios Bin file Dell server 220
    by hazem3636
    hi everyone
    i need dump file for dell server r220
    i have download Flash BIOS executable file but i dont know how to conver it to Bin file
    i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
    if anyone has this method please need his supporting .
    all the best
    EXE file is attched and Original Bin file from the Bios Chip is attached also
    and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
    11-05-2022, 06:20 AM
