iMac P/S posts then shuts down
  • godonr
    • May 2009
    • 111
    I know info about iMac supplies has been posted before but I didn't want to jump NWD's thread. Also noticed several senior members appear to have become very familiar with this bugger lately. I'm hoping someone can point me in the right direction with troubleshooting a supply which comes up for a minute or so then shuts down. While up, all voltages are there. It's an AcBel Apple #661-3350 (614-0296), 180w in a first generation 20". It's had any bulging caps replaced (low ESR) and shows no visible signs of burning coils or diodes. I know it's the supply because the iMac works fine with a known good. Best case scenario, did anyone ever locate a schematic for this guy?
  • Toasty
    • Jul 2007
    • 4171
    Re: iMac P/S posts then shuts down
    No schematic has been found. Certain areas have been figured out as needed.
    All 9 caps in the secondary should be replaced, bulged or not. But, the other 4 small caps are easily replaced, and since you're there... why not? The mains caps are not showing any issues, and it's a personal call as to whether or not to replace them. Again, you're there and it's only another $7 for both of them.
    What caps did you use? Brand & Series please.
    If it's shutting down:
    a) the unit itself is sensing an internal fault and shutting itself down
    b) the mobo is sensing a voltage problem and sending a signal back to it to shut down
    Toast
    veritas odium parit
    • godonr
      • May 2009
      • 111
      Replacement caps are Sanyo SE 105degree range.
      • Toasty
        • Jul 2007
        • 4171
        I do not have a SE series data sheet, but I have seen good reports on them. These are the green w/gold printing, correct?
        Where did you get them from? There are fakes of Sanyo on eBay.
        The units I have in the shop have been recapped by their owners with Nichicons, UCCs, and some Panasonics. All depends on fitting them in there.
        Toast
        veritas odium parit
        • godonr
          • May 2009
          • 111
          Yes, they're the green and gold and are also in my "known good" supply. The specs are top drawer and from a good source. I'm currently pulling everything off another board to ID the SCRs, regulators, etc. There's 3 transformers on the board with OEM numbers I can't cross. There's actually 11 (15 total) caps above T2. A 120uf/50v hides beneath the heat sink for HS3. I know the caps are ground zero and was hoping you guys discovered something additional to look at next. Any ideas would be great. I have 4 to fix! Thanks
          • Toasty
            • Jul 2007
            • 4171
            Heh, my bad. The models we've been dealing with are 614-0293 & 614-0294.
            All 4 units are same problem? Runs then shuts down?
            Pics would be helpful as I can look at your layout and perhaps cross your info to what I have in front of me. There is a diode on them that should be checked. It's a switching diode of 3A or better on the primary side of the heatsink that divides pri/sec.
            Have voltages been verified as correct?
            How about when connected to unit? (loaded)
            Scoped all the voltages for ripple?
            All tested on same computer? A mobo problem can be hidden by a good PSU. Maybe the PSU's are picking up on it where the other one isn't?
            Toast
            veritas odium parit
            • godonr
              • May 2009
              • 111
              Right, those are for the 17" I believe. To answer your 4 Q's: voltages have been checked loaded; scoped for ripple (clean); and tested on different units. These guys are known to act like this when the HD's going bad (or just has a problem). Anyway, I've got more to check. I'll get more info together later. Have to checkout now. Appreciate your input. These are really great units with a few unfortunate design flaws (and a bad batch of caps). That's Apple for ya! Thanks for the help. I'm out for now!
              • godonr
                • May 2009
                • 111
                Apologize for the delay... attached are two jpgs of the 20" iMac p/s. To load the supplies for testing, I jumper 15 (3.3v on/off drops to 0v on power up) and 16 on the 22 pin plug. It carries the same voltages you found on the 17" supply. The problem I'm having with some supplies is after a recap, I'll plug the supply into a known good mobo and the on/off voltage won't drop. Again, I have a known-good power supply which responds correctly with the same setup so I don't think it's the mobo. At this point, I can ID most components (except the SMDs which I don't think I could replace anyway) and would like some advice on where to look next. Thanks
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I got some Sanyo I suspected as fake from eBay myself and so I sent some in to Sanyo for validation. Sanyo confirmed they are fake.
                  One these particular fakes....
                  The fakes have a Y vent instead of a K vent.
                  The gold [yellow] color is too dark. [That color looks 'washed out' on real ones.]
                  The "V" [for volts] is shorter than the letting for the numbers in the voltage rating marking [on legit ones they are same height.]
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • godonr
                    • May 2009
                    • 111
                    Right -- I didn't get these from ebay. They are actually factory and all have K vents. That's why I'm looking for the next likely thing to go after the caps. I now that's a stretch, but...
                    • i4004
                      • Oct 2006
                      • 2029
                      then you have a gold-mine!
                      you should scope the working unit(esp. the feedback loop, ie elements connecting secondary to primary) vs. these problematic units.
                      if it has pwm ics od any cort, concentrate on them..if not, concentrate on transistors...
                      naturally, if scoping the hot(primary) side be extra carefull...think twice for every move you make...
                      on solder side? any identifiable chips there?
                      • Toasty
                        • Jul 2007
                        • 4171
                        While plugged in to mains 115v (isolation transformer please) but disconnected from mobo and without 15 & 16 jumpered, compare voltages at mobo plug of known good supply to rebuilt unit.
                        Then, jumper 15 & 16 and compare.
                        Please report back.
                        Toast
                        Attached plug pinout jpeg for reference.
                        veritas odium parit
                        • godonr
                          • May 2009
                          • 111
                          Not sure I know what pwm ics od any cort refers to. The solder side has a LM339M, a Z441 and a WT7515. Know what the LM is but have to look up the others. There's also lots of SMD transistors wiht 1P> and 2FL.
                          • godonr
                            • May 2009
                            • 111
                            On a good supply I see 20v @ 22, 5v @ 15 and 5v @ 9 unjumpered;
                            Jumpered: 22@24v, 21@5v, 20@5v, 19@12v, 18,17,16 gnd; 15@0v; 14@gnd; 13@12v; 12@3.3v, 11@gnd, 10@12v, 9@5v vsb, 8@5v pg, 7@gnd, 6@5v, 5@gnd, 4@5v, 3@gnd, 2@3.3v, 1@3.3v.
                            • godonr
                              • May 2009
                              • 111
                              Toast -- sorry about that, a senior moment... on a bad supply, when it's jumpered 15 goes to 0v but 22 stays @ 20v and 5v @ 9. Whatever switches to jump 22 to 24v also brings in the other voltages and this isn't happening on the problem supplies!
                              • i4004
                                • Oct 2006
                                • 2029
                                if toasty doesn't produce better idea:
                                should be "of any sort"..typo
                                pwm ics are its brains, they modulate pulses on the transformer to produce just right amount of power to satisfy the needs of gear it's connected to(in this case mobo)
                                wt should be something to concentrate on
                                http://pdf1.alldatasheet.com/datashe...TC/WT7515.html
                                although it's just a protection unit...but oversensitive protection unit can cause such issues...
                                see if those faulty psus are latched into protection first...
                                it seems z441 is main pwm ic but i dunno will we find its datasheet...
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  Ahh. The +24 volt isn't coming up. 9 is correct and should stay at 5.1v.
                                  Look for a KA78M24 3-legged regulator in a TO-220 case mounted on the heatsink. On the 17's it's marked M6 on the circuit board. Easiest way is to follow the 24v lead back from the connection on the board. Going backwards you should hit a 1000uF @ 35v cap, then this device. The cap is across its output and there is a zener diode on the input leg. It follows back to those 2 diodes D20 & D?? in front of transformer T2. The input to the regulator (per spec sheet) is supposed to be 40v for a 24v output.
                                  See if your getting that voltage at the input when you've jumpered it "on". Again, testing it against the good supply.
                                  Toast
                                  veritas odium parit
                                  • godonr
                                    • May 2009
                                    • 111
                                    Toast --I have a top244y @ m6. If you look at the attachment it's HS2. If it's the 24v regulator it has 6 legs! I have a 17" supply and see what you're talking about. The 20" layout is somewhat different. I need to find what's on each leg of the top244y.
                                    i4004 - those pwms are SMD'd to the solder side of the board and I pretty sure I don't have the skill (or equipment) to desolder them. Any way to verify them in place?
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      Nope, thats the switcher (TOPSwitch). We'll get there in a bit.
                                      It's the 24v voltage regulator I'm interested in right now. Follow that 24v lead back through the circuit. Unless the 20" doesn't have it, but that would be odd. The 17 & 20 supplies are similar to a point.
                                      Toast
                                      veritas odium parit
                                      • i4004
                                        • Oct 2006
                                        • 2029
                                        first see where toasty will lead you, and if that doesn't succeed we'll go there.
                                        i didn't mean to desolder them, but to scope particular pins, checking bad psu against good one. in that (minute, you said?) time-span the bad one actually works.
                                        but again, follow toasty's lead...if it fails we'll think about backup plans.
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
                                        • tommy97
                                          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                          by tommy97
                                          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                          Any ideas what might've...
                                          04-20-2024, 04:48 AM
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
