iMac P/S posts then shuts down
  • godonr
    • May 2009
    • 111
    Re: iMac P/S posts then shuts down
    Toast -- the rail from 24v goes through SB340 diode > 330uf/35v > L1 > D26 (marked UGIODCT 0420) with a symbol under it that looks more like a MOV. Is that what we're looking for?
    • Toasty
      • Jul 2007
      • 4171
      No. That's a dual Schottky (probably common cathode) switchmode rectifier. Symbol sort of looks like 2 Zeners cathode to cathode? That's an extremely heavy piece (20A) for a 24v line that's rated what? 1/3 amp?
      C59 is the 330uF cap? You should have the 20v across that cap at standby, and 24v when "on".
      You have L1 out of circuit, correct? C59's positive is connected to L1. Does it exit the coil at the lead directly across from it (center pin of D26)?
      You should have continuity between that center pin on D26 and the 24v lead to the plug. Ohmmeter positive tip to center D26, neg to plug #22.
      If that's all correct, then this uses a much different method (buck regulator) of generating the 24v line than the 17's. Yet, so many of the components for the 24v on the 17's are in the same places.
      Toast
      veritas odium parit
      • godonr
        • May 2009
        • 111
        Toast -- You have it exactly right. That answers why I couldn't find a 24v regulator. What exactly is a buck regulator? I can ID all of the components if it helps. The heatsink @ HS3 has that dual schottky and another MBR20100CT (0440), a PS30L45CT, a KA78M15, and 2 MBR2045CTs. There's several TL431s, two 20N60C3s (one is JW434, tone is NK434 Darlingtons?), an A1013 (Q14). Does this info help? And, yes C59 is a 330uf. I appreciate all the info so far. Is there a next step?
        • Toasty
          • Jul 2007
          • 4171
          Can you get a pic of the backside of the board? If you can identify the chips back there (PaintShop-Photoshop?) it will make some explanations a bit easier.
          >>You should have the 20v across that cap at standby, and 24v when "on". <<
          Do you?
          >>Does it exit the coil at the lead directly across from it (center pin of D26)?<<
          I may be mistaken on the buck regulator (properly: buck converter) setup there. Since I can not get a proper identification on the UGIODCT device. It certainly appears to be connected as a dual-Schottky would for a buck converter.
          I did a bit of research and am going to say that this is actually a push-pull converter. Starting with the 2 transistors Q12 & 13 in front of T1 which alternate driving T1's primary. Then T1's outputs go through D26 and the 2 similar devices right next to it. On to L1 and the cap and out through the diode D21 to the +24v lead. I'd also venture a guess that there is a PWM chip on the solder side down near Q12 & 13 that is getting feedback from one leg of L1.
          T1 is not just providing 24v, it also appears to be producing the 12v & 5v also. The inputs to L1 seem to go directly across for output. Going from down of the stripped board to up. On the 5 output legs, I would expect to see, going left to right, 24v, 12v, GND, GND, 5v.
          See what you can confirm from my theories please. My puzzlement is: If the 12v & 5v come up when PSU is jumpered "on", then why doesn't the 24v? What's keeping it at 20v?
          Toast
          veritas odium parit
          • godonr
            • May 2009
            • 111
            Give me a bit to get it all together and I'll get that pix. Also, I may have confused things as to which supply I've been working on. The one we're talking about gives nothing but 20 & 5vsb when jumpered. That's the more common problem encountered before and after recapping. I do have one supply which comes all the way up (all voltages present, plugged into the mobo) then shuts down and I know I mentioned it first. Sorry if that confused things but my focus has been the non-responsive units.
            I can work whichever is best for you!
            If it helps, as you suspect, there is a pwm 3845B Z442 (m2) right under T1. Also, where the two feed wires off T1 go to the board just below C53, there are two solder side pwms LM339M (M10) and WT7515 (M12).
            Let me double check the C59 -- I know on the non-working it stays at 20v. I'll need to pop the top on the working one to verify the 20 to 24v swing. Also, as far as I can tell the coil lead is directly to the center pin of D26. On an intact board, continuity from pin 22 to center pin of D26 can be read.
            Let me get more answers for you. If responses are a little slow it's because I'm on the job and having to fit this in all the other things we do around here. Thanks for your help and patience!
            • Toasty
              • Jul 2007
              • 4171
              #26
              >>The one we're talking about gives nothing but 20 & 5vsb when jumpered.<<
              Okay. So the 5v, 12v, and 3.3v are missing then? We're working in the wrong area then.
              What of the other supplies? I thought they all had the same symptoms. Are you saying each one is/has a different problem?
              You actually have a great solution in front of you. If all of these are identical, then take your working unit and start comparing voltages at matching points across the board(s). Set them up and jumpered on. Then start checking from the component side at the transistors, transformers, diodes, anything that has a clear leg that you can meter.
              Take a clear pic, blow it up and print it. Then mark off each point as you go with the voltages. You can make one for each unit, and keep it with it so you know where to go looking for the problem.
              Looks like I picked a bad week to stop drinking...
              Toast
              veritas odium parit
              • godonr
                • May 2009
                • 111
                #27
                Here's the solder side of the power supply. Upper left is M12 over M10. Middle of board is M2.
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  BTW:
                  3845B is a PWM
                  LM339M is a quad comparator
                  WT7515 is a protection IC that monitors 3.3v, 5v, 12v for over/under voltage
                  veritas odium parit
                  • godonr
                    • May 2009
                    • 111
                    #29
                    I apologize for the confusion. To date, I have repaired 16 of these just by recapping. I have about 20 more problem supplies. As I started on them, they would come up without the 24, 3.3, 5 and 12v present. So that's the batch I'm trying to determine "why" on. This problem appears common to this supply after a multiple cap failure. Whatever area of the supply tells it to switch on the voltages is where the problem is, right? Believe me, I know what you mean about the stop drinking.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      No. The area that tells it to switch on is finding a fault somewhere and telling it NOT to switch on. Most likely. Possibly. Perhaps.
                      Try the troubleshooting with the good vs. bad unit voltages first. If you have a scope, you can check the TOPSwitch and see if it's running. Or, just lay the probe down along each of the transformers and see if there's a waveform being generated.
                      Toast
                      veritas odium parit
                      • godonr
                        • May 2009
                        • 111
                        #31
                        By topswitch, we're talking M6? TOP244Y with 6 legs? What would should I expect there?
                        • Toasty
                          • Jul 2007
                          • 4171
                          #32
                          Ya gotta start grabbin' datasheets man...
                          Happy reading!
                          Device will output about 60-130kHz signal, depending on setup. The newer supply that nwd had was running about 60-63kHz under load. I was getting 130kHz in between the transformers with a loop probe to my freq. counter.
                          Toast
                          veritas odium parit
                          • godonr
                            • May 2009
                            • 111
                            #33
                            i agree... but do appreciate the spoon-feeding so far. Haven't worked much with newer power supplies so i was trying to get a feel for where to look. You gave me some good tips... appreciate it. Will post back if i find the source. Thanks again
                            • Toasty
                              • Jul 2007
                              • 4171
                              #34
                              hmmmm? Much too quiet...
                              How's the "homework" going?
                              veritas odium parit
                              • godonr
                                • May 2009
                                • 111
                                #35
                                Haven't given up but I may have reached the wall that separates the newbies from the real techs. I'm having trouble locating the "source" for the various voltages- 3.3, 5, 12 and 24. Example- on the LM339 of a working supply, I see input 2 with +20 & -20 and +24 (Vcc)Supply yields output 2 of 0; input 3 has 0 & 2.5 and 0 (Vdd) Supply yields 3.3vdc; input 4 compares -1 & +2.8 to yield 3.3; input 1 does -2.6 & +3.1 to yield 3.3 at output 1. This is on a psu turned on with the 15/16 jumper. Now the one thing I've noticed on supplies which either run and shut down or won't go beyond LED1 lighted on the mobo (I think I saw where you guys discussed the 4 LEDs this iMac uses to indicate good power-- if not, LED1 just senses voltage from the psu, LED2 acknowledges startup and peripherals, LED3 is for display (to 20" needs the 24v here) and LED4 doesn't come on unless there's and overheat problem,) is the lack of 24 Vcc. And, while I can find it at TPs I lack the knowledge/skill/good eyesight to track it to its source. I think its at UGIODCT 0420 because after T1 puts out two 12v rails UGI shows 12v on its outside legs and 24v on the center. This carries up through L1, C59, D21 and out +24 to pin 22. Bingo that should be it, right? Not exactly, I've tested some supplies where 20v appears on the cathode side of D21 and 0 on the anode side. I've no idea where that's coming from. Anyway, I think the UGI rectifies the two 12s from T1 to yield +24. Also in that area under T1 are a bunch of smds including M2 which is a 3845B Z442 PWM which I know what it does but not how to tell what it's doing here. I'm also not sure how to read the TOP242 correctly and wondering exactly what its "multi-functions" are being used for. It seems like its protection circuits like WT7515? All this regulation is getting me confused!!
                                • marky
                                  • Aug 2009
                                  #36
                                  hi, i'm fixing my brother imac g5 with psu pn: 661-3350
                                  does anyone have the pinout for the 22pin connector on the output of
                                  the powersupply? i want to make sure the psupply is good first.
                                  i have repaced c40, c63, c49, c47, c52, c45, c1 in the supply so far.
                                  tnx, mark
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Welcome Marky -
                                    >>i'm fixing my brother imac g5 with psu pn: 661-3350<<
                                    - So I'm clear, it looks like the pics in post # 8 in this topic, correct?
                                    >>i have repaced c40, c63, c49, c47, c52, c45, c1 in the supply so far.<<
                                    - Were the caps failed and you're replacing them or are you doing a preemptive recap?
                                    - What brand & series have you replaced them with?
                                    >>does anyone have the pinout for the 22pin connector <<
                                    - See post # 12 in this topic for picture of connector. FYI - Numbers are on the wire side of the connector (tiny).
                                    Voltages measured from ground are as follows:
                                    3, 5, 7, 11, 14, 16, 17, 18 - Ground (-)
                                    1, 2, 12 - 3.3v
                                    4, 6, 20, 21 - 5.1v
                                    8 - (Power Good) - 5v
                                    9* - (Standby) - 5v
                                    10, 13, 19 - 12v
                                    15 - On/Off - jumper to ground (14 or 16) to run supply
                                    22* - 24v (may read about 21v until switched on)
                                    * Always present when unit is plugged in but not switched on.
                                    If you encounter problems with the PSU or system, please open a new thread. It's easier to focus on one unit at a time and keep on track as to which problem we're dealing with.
                                    Cheers!
                                    Toast
                                    veritas odium parit
                                    • marky
                                      • Aug 2009
                                      #38
                                      thankyou toasty, that's exactlly what is was looking for.
                                      6 caps were bad- c 40, c49, c47, c52, c1, c53 - i actually tested them
                                      with my ESR meter. I replaced all of the other electrolytic caps too. the brands i used - decent brands from my local electronics supplier that i have used for years, i didn't pay attention to the manufacturers, they're already installed. i've used the his stock in the past with no problems, but i do recall 'rubycon' & 'elna'.
                                      series - again i didn't look.
                                      i installed the ps into the mac, i get led 1 on, but it doesn't power up via top switch nearest fan. i'm going to remove ps, check more voltages & then force ps 'on' via jumperring of pin 15.
                                      mark
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        See Post # 10 in this thread for LED indications:
                                        https://www.badcaps.net/forum/showthread.php?t=7124
                                        You may have some motherboard caps to deal with also.
                                        Toast
                                        veritas odium parit
                                        • marky
                                          • Aug 2009
                                          #40
                                          hi, i do get the 20vdc & 5vdc standby voltage, but the rest of the ps doesn't fire up when shorting pin 15 to 16. so i'll check the 'not quite their' thead u refered to toasty,
                                          tnx, mark
                                          • ryogadan78
                                            iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                            by ryogadan78
                                            Hi guys, I need your help again.
                                            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                            06-10-2025, 03:49 AM
                                          • Stephen
                                            iMac M1 DFU restore issue
                                            by Stephen
                                            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                            this is the message it gives me with the error
                                            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                            03-07-2025, 12:19 PM
                                          • Stephen
                                            iMac 27” 2020 Boot issue
                                            by Stephen
                                            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                            08-16-2024, 09:32 AM
                                          • tommy97
                                            iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                            by tommy97
                                            we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                            Any ideas what might've...
                                            04-20-2024, 04:48 AM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
